Question about Acer TravelMate 4100 Notebook
  • Acer Master
  • 5,568 Answers
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Posted on Jan 22, 2009
How reset bios password form a acer travelmate 240
You will need to turn your travelmate upside down and remove the ***** from the hard drive panel or Ram cover...try both.You will see a small battery(cmos battery). If you can see where it is plugged in and can reach it,unplug it for about 10 seconds and plug back in then put your covers back.That should reset your bios so you dont need a password.You can go back in your bios at a later time and set a new password if you wish :)
Aug 23, 2014 | Acer Unlock Bios Password: Aspire 7735g...
Acer travelmate 2700 bios password and where is the CMOS battry on the mother board
your bios battery is soldered into the mainboard, its under the keyboard, next to the modem board and the bios chip itself.
In order to get to the battery you would first have to dissasemble the laptop, remove the keyboard, power buttons, and the top of the machine. You may also have to remove the display if its holding the top of the cover in place.
Removing the battery is no guarantee of reseting the password. You need to study the bios chip and find out which pins of it you need to short in order to reset its memory. In some cases the password might be stored on another chip.
Oct 09, 2011 | Acer TravelMate 2700 Notebook
My acer travelmate 4100 has crashed. I've tried to go into safe mode to fix it, but the screen turns blue again and nothing else seems to work. This has happened before, bit it was fixed without any...
If you have windows CD or DVD
Boot from CD (you have to go to the BIOS to change the boot order: F2, F10 or delete key)
Then Run the Repair Console
When you are in the Repair Console Screen
Type 1
Then Type your Admin password
Then: chkdsk -r
Hope that this help
Nov 15, 2010 | Acer TravelMate 4100 Notebook
I have acer notebook 4100, I forgot bios password now I can't recover my windows. I have recover cds and all manual book with full packing. thanks Wajid abbasi
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Sep 08, 2010 | Acer TravelMate 4100 Notebook
My acer travelmate 4100 will not power up when I switch on. The green power button is lit but the screen is blank and and there is none of the normal "booting up" noises it's just silence :-( I have tried...
hi michelle, first check to see if you can even get to your BIOS. if that is not posible then you might have either a power supply or motherboard issue. for either one of those you will need to send for repair.
Aug 11, 2010 | Acer TravelMate 4100 Notebook
Acer travelmate 4100 works fine with no battery
Try to use another OS, like Ubuntu Live, and see if the mouse and KB will freeze. If they wont freeze, It is better to reinstall the OS.
If they will freeze again with Ubuntu, then I am sorry to tell you that the battery life has finished.
The only thing to do is to replace it for another one new.
Thanks for rating!!
Apr 21, 2010 | Acer TravelMate 4100 Notebook
Is there an overide bios password for my acer travelmate 2450 as i can not access the bios as it asks me for a bios password that i dont have
There is a "jumper" that needs to be shorted and power then applied to the board. Take the memory cover off the bottom of the case, take the first memory stick out, look on the motherboard for a set of points that are labeled J3 or Cmos reset. You will have to hold a thin piece of jumper wire on these points to "short" the connection while power is applied to the board, this will reset the Cmos and clear the password.
Sep 27, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 2440 theres power only the screen its pure black.
Try reseating the RAM modules first. The RAM may be faulty or reseating to make proper electrical connection. Get the RAM tested in another laptop or at your friendly computer shop.
Can you get into the BIOS configuration?
Did you power up the monitor first then the laptop? This method will divert the video information to the external video port first automatically.
If you don't get an image on the monitor and the hard drive doesn't appear to be spinning, then you could have a faulty motherboard.
Jun 15, 2009 | Acer TravelMate 2300 Notebook
How do i replace the bios battery in an acer 354te
Hi there.
It could be a couple of things, to rule out the inverter or loose cable connect a external monitor to the laptop (you may have to use Fn and the F key that loos like a TV to switch screens) if you get a display on the external monitor then its definitely the inverter, screen itself or a dislodged cable.
If you want any info on what to do about it please post back.
Good luck and thanks for using FixYa!!
Mar 15, 2009 | Acer TravelMate 354TE Notebook
Acer TravelMate 4100 Notebook Logo
206 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
