Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
TROUBLESHOOTER MY PRINTER IS SAY TROUBLESHOOTER ROUTINE MAINTENANCE AFTER PAPER JAM
  • 124 Answers
I'd like to help if I can. I assume that you were able to clear the jam by removing the cover on the back of the machine. Be sure that you have replaced the cover correctly. If you didn't, the printer will try and troubleshoot (determine what the problem is) what went wrong after you removed the back cover. I have this printer myself and sometimes putting the back cover on is a pain. One last thing, Make sure you got all the paper out as well.
If my assistance was of value to you, please give me a rating. Thanks for using FixYa.com
Posted on Jan 28, 2009
  • Bernie Thames
    Bernie Thames Jan 30, 2009
    Do you still need help? If you're doing ok and my help was appropriate, I'd appreciate your feedback. Thanks!
Error 13.01.00 - Jam in Tray 2. There is no jam. We've changed the pickup roller and separation pad twice. Problem started after technician installed the first pickup roller/separation pad set for routine...
try it without the separation pad. Since the problem started after the maintenance, it may nt be in properly. As you are getting the rubber on the paper, the roller is turning, but the paper is not going anywhere giving the error
Oct 23, 2013 | HP LaserJet M3027 MFP Printer
MFC-240 I had a paper jam the other day and I
May be you should have the printer checked by a qualified technician.
I guess that when you aunt removed the paper, she did it by applying excessive force causing damage to the printer mechanic.
Mar 15, 2010 | Brother Multi-Function Center MFC-240C...
Unable to init.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Dec 20, 2009 | Brother MFC-5840CN All-In-One InkJet...
Printer stopped printing and says to study troubleshooter and routine maintenance. What maintenance do I need to do?
you need to install the printer kindly follow this steps
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Sep 18, 2009 | Brother MFC-3240C All-In-One InkJet...
I have a color MFC 5 in 1 printer
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. Sounds like something is jamming.
May 16, 2009 | Brother MFC-5440CN All-In-One InkJet...
Had paper jam now the printer says routine mantiance needed chapeter 34 trouble shootingg user guide (do not have guide :-) )
Usually, routine maintenance messages won't cause any problems.
Here is a link to the manual. There is a section on routine maintenance, but it isn't on page 34. Take at look at that and let me know if it helps you. I'll be doing the same. Please get back to me.
Dec 07, 2008 | Brother Office Equipment & Supplies
Mfc-5460cn
Now the printer bar is all black lines neatly lined up and I can't even shut it off!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Put in new cartridges and now printer says unable to print routine maintenance no paper jam or forien objects
Try resetting the factory presets. While in maintenance mode, press either 01 or 91. Wait for the machine to beep at you again, then press 99 to get out of maintenance mode. You may also have to let the unit cool off (power off for about 15 min) and try the reset code and the 99 to get out of maintenance code.
May 19, 2008 | Brother Office Equipment & Supplies
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
