Question about AEG Washing Machines
Motor starts in fast speed causing violent shaking
Seems like the control card could be the problem. But just wanting to here if anyone has had the same problem
  • AEG Master
  • 17,130 Answers
This can be due to improper drum setting or the suspension being out of sync. in alignment. Also if the wash cycle does not start in sequence of opening inlet valve and then filling up to attain water level and then to switch on the motor, then it be related to a control board failure.
Posted on Jan 12, 2013
5 Suggested Answers
  • 15 Answers
SOURCE: Washer shakes, as if out of balance, after all water is drained
Biggest problem i get on the front load machines are spinning and draining problems. First thing to check is make sure your soap is not foaming up. If you see alot of suds in the machine when it is washing switch brands h.e. soap is best but he liquid tide has been a big problem with suds. Next make sure you put equal size items don't mix heavy and light items in machine as this may have off balance issues! Next check the coin and pintrap if it has one some machines have filters on the front of the machine that need cleaning.After these have been checked see if the machine has any unusual noises or odors when used rubber burning odor or electrical odor when in use may indicate a overloading or internal problem with the machine.
Posted on Oct 10, 2007
SOURCE: drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Posted on Jul 15, 2008
  • 112 Answers
SOURCE: washer shakes violently
The drum mounts to a spindle on the back. On these units, it is common for the tripod mounts for this particular design to crack and break. On every call I have had for a terrible vibration on these models, this has been the problem. The remedy is to replace the front and rear tub, as well as the basket. It is also recommended that you replace the drain pump at the same time. Most of this should be covered under at least a parts warranty.
Posted on Oct 25, 2008
garing
  • 998 Answers
SOURCE: Violent shaking on spin cycle
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Posted on Aug 17, 2009
97 Taurus sometimes rpm's rev up on its own causing rpm gauge to go down/up really fast and car cuts out almost violently
Check with dealer if your car has a "idle speed control motor"?;I'd start with that and make sure your car's had timing done right. Hope this helps. Alberto
Jan 31, 2014 | Cars & Trucks
Violent Shaking
No check engine light on? If it jumps rapidly, then it can only be due to the transmission changing gears, or slipping clutches. Either way, there should be a fault code set in the PCM. You need to get it scanned first to know the fault code.
May 26, 2013 | 2004 Jeep Grand Cherokee
2001 ford taurus, 3.0 vulcan motor. just rebuilt the whole motor, backfires out of the intake, seems to be out of firing order. i triple checked my work and can't find the problem. whistling sound of...
Back firing out of the intake is because the valves/cams are not set right. When you did the timing belt . did you set the crankshaft mark at top dead center of the compression stroke. If it's at the exhaust stroke this would cause backfiring and violent shaking.
May 22, 2011 | 2001 Ford Taurus
My jeep starts shaking violently when it reaches 55 miles/hr.
no its your wheels well out of balance get them looked at first fitting a damper wont stop this shimmy
Jun 04, 2010 | 2000 Jeep Grand Cherokee
Malber WD1000 won't hi-speed spin
check if the drum assembly is loose, but it seems like one of the mounting arms or shocks broke.
Jul 10, 2009 | Washing Machines
I HAVE A 1991 TOYOTA CAMRY XLE WITH OVER 250K MILES ON IT, AND AT LOW SPEEDS THE TRANSMISSION WILL VIOLENTLY START SHAKING CAUSING MY WHOLE CAR TO SHAKE AS WELL
Holy **** you need a new transmission or check the fluid in it. Cus that shaking means the trans is locking up and doesnt want to move get that checked out soon. Or the mounts could be gone also. But either way thats not safe. Hope that helps
May 02, 2009 | 1991 Toyota Camry
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
2000 Pontiac Sunfire that Shakes Violently around 45-50 MPH
Check the ball joints and cv axles this could cause the car to shake violently and most tire stores will check them for you for free.
Dec 20, 2008 | 2000 Pontiac Sunfire
Shakes violently and bangs on spin
transit bolts not removed. also can be caused by motor not winding up gradually into spin - usually a motor tach fault. most likely cause is transit bolts
Oct 18, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
64 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
