Question about Acer Aspire One PC Notebook
SDHC card compatibility for my card reader
I have an Acer Aspire One D270 netbook and I am wondering if it can accept SDHC cards since on the specifications for supported memory cards it refers to: Secure Digital Card (SD) Memory Stick xD-Picture Card MultiMediaCard (MMC) Memory Stick PRO
  • Acer Master
  • 32,281 Answers
Yes it should work with SDHC cards.
Posted on Jan 12, 2013
dbarchitect
  • 150 Answers
SOURCE: how to eject a memory card from the 5-in-1 memory card reader on an acer laptop?
jmorgan123 is correct and to make it a little more clear, what happens is when the card is injected in to the slot, you press it delicately until it "seats" in the slot.
To release the card, gently press the card again as if you were to push it further in to the slot and the internal latch will release it, then let go of the card and the spring will let the card loose, then you pull the card out the rest of the way.
If this helps, select the FixYa! ThankYa!
Posted on Dec 01, 2007
  • 121 Answers
SOURCE: Acer aspire 5610z card reader
goto to start menu
click on my computer--this will show all drives and devices
find your media reader drive
right click on that--goto properties
click and you'll see different tabs, so go thru each of them
and try to restore all defaults--
not sure what os you are running on so let me know if i was of any help to you.. thanks, d
Posted on Feb 27, 2008
  • 16 Answers
SOURCE: Acer Aspire One multi-card reader will not work
check if the drivers are installed
Posted on Jul 07, 2009
lserni
  • 466 Answers
SOURCE: How to eject RS-MMC card from card reader slot in acer 4736 ?
Usually there is a spring latch: press the card deeper into the PC, and it will click out.
If it doesn't, the spring may not have engaged, or may be broken. To extract a stubborn memory card, it usually has two grooves on the top and bottom to allow extraction by hand using your fingernails. Some cards don't have the grooves though, and for those you can use a pair of tweezers, or use two strong sewing needles as "prybars" from the left and right side of the card simultaneously.
If it still doesn't work, something went really really wrong with the latch and you'd best send it to assistance. As an extreme resort ONLY, wet the short side of an unfolded paper clip with Loctite glue, and taking the utmost care not to touch ANYTHING but the short side of the memory card, stick it to the memory card's short side. The traction made available by half an inch of Loctite on a steel paper clip should be enough to tear the memory card apart, let alone extract it. But if you need that much force, chances are that you'll end up destroying the reader: that's why I suggest going to the assistance if things come to that.
Posted on Oct 29, 2009
  • 497 Answers
SOURCE: do you need an adapter 4 a memory stick pro duo in a 5 in 1 read
No, just insert the Memory Card in the 5-in-1 Card Reader slot. The Memory Card will appear on the "My Computer" or "Computer" window. Click on that to open the contents of the Memory Card.
Good Luck!!!!!!
Posted on Nov 30, 2009
How do i get Sim card drivers for acer d270
Hi
The Acer d270 appears to be a netbook and not a mobile phone. I have had a look at the full data sheet here
Aspire one D270
by pressing the Full data sheet link just below the general description. There is no mention of any facility to install a SIM card and as such they are very unlikely to have developed any drivers for SIM cards.
Dec 05, 2014 | Acer Cell Phones
I put my sd card in slot to download pic and its not reading
If you have not used this card with this laptop before it is possible there is an incompatibility with the card type and the reader. SDHC cards are generally no compatible with card readers built into laptops. IT is due to the compression algorithm used to increase the storage capacity on the card. There is no PHYSICAL difference the higher storage capacity is made possible by configuring the way data is stored and revision 1.0 of card readers arent compatible. Try going to Acer and downloading a newere version of the card reader software if this doesnt work, try an older version card if possible.
Aug 02, 2010 | Acer Aspire 5920-6727 Notebook
Can I upgrade my Acer Aspire E380 SD-Card reader to SDHC compatible
Yes you can upgrade acer Acer Aspire E380 SD-Card reader to SDHC compatible
May 20, 2010 | Computers & Internet
ACER ASPIRE T180
This is a difficult one. It could be the card itself or the card is not formatted.
You may need to buy a card reader that has itself own driver for this format.
http://support.acer-euro.com/drivers/desktop/aspire_t180.html
Try looking on the ACER sirte for a driver taht is compatible...
other... buy a card reader at www.newegg.com that is compatiblie.
Best of Luck,
Sagacious1
Aug 06, 2009 | Acer Aspire T180 PC Desktop
Acer Aspire 4520 doesn't read SDHC cards
No, there is a simple fix. However, it involves flashing the BIOS on the laptop.
Don't worry, there's not much chance of it going wrong as long as you follow their steps of flashing the BIOS (Incidentally, it's stored on most laptop hard drives).
The reader will accept a larger chip if the updated BIOS on the laptop manufacturer's website is written to do it. Contact the manufacturer via email first just to make sure.
Jul 27, 2009 | Acer Computers & Internet
Acer aspire integral SD card reader
install the proper dirver by opendriver.com and enjoy. raheelahmadkasuri@gmail.com
Jul 12, 2009 | Acer Computers & Internet
My netbook screen resolution is no good for canon instal disk
You didn't provide what netbook you got, but most netbooks today got built in SD-card readers. If your netbook does, the best solution is to remove the card from the camera and insert it into the netbooks card reader. The Canon G9 supports SD-cards, as well as SDHC, MMC, MMCplus and HC MMCplus compatible cards. I suggest using a SD or SDHC card.
You will not need to install canon software to access your pictures if you use the card reader, you will be able to access and copy/move them from the memory card in explorer (or equalent if you use Linux on your netbook). Also, it's a much faster way to move pictures from the camera to the computer, because the card reader interface is a lot faster than the USB interface to the camera.
If your netbook does not have an internal card reader, you could buy a SD card with built in USB, such as this one: http://www.cdrdvdrmedia.com/ultra-sd2-card-2gb-sandisk.html This SD card behaves like a normal memory card in your camera, but plugs directly to an empty USB port on your netbook. The card will be accessable as any removable storage, in Explorer (or equalent if you use Linux).
A third solution would be to get a cheap USB 2.0 card reader. Almost any cheap USB 2.0 accepts SD cards, and would be a lot faster than connecting the camera to the netbook with a USB cable.
I hope this help you!
/Chris
Jan 19, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
SD Card Reader Not Working on Acer Aspire 5600 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
Jul 15, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
