My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
  • Washing Mach... Master
  • 17,130 Answers
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Posted on Jan 12, 2013
SOURCE: GE washer repair
to start I will never again buy another GE product for as long as I live. I am having the same problem w/my GE washing machine. I have to manually turn the dial to make it go thru its cycles. the problem is the 'timer' must be replaced. good luck trying to get their customer service dept to help you with anything. they are useless.
Posted on May 09, 2007
  • 29 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
SOURCE: Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Posted on Dec 16, 2008
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My Electrolux F/Loader won't start filling. I select a wash cycle and start . The screen shows 'filling' but only makes clicking noises.
Thank you for your post, friend!
I see that your Electrolux washer won't fill during the cycle and makes a clicking sound. This clicking sound could come from either the motor or the water valve. In order to locate which component could be causing the issue you may need to disassemble your washer. I would recommend having a professional technician out to properly disassemble the washer to prevent any personal injuries or future issues. I hope this information is helpful to you. -Matt
Apr 17, 2016 | Electrolux Washing Machines
Frigidaire washer water will not drain
Hello - Is the drain pump make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Jan 14, 2013 | Electrolux Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Not draining burning smell electrolux front load
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 25, 2012 | Electrolux EIFLW55H Front-Load Washer with...
WASHER WILL FILL WITH WATER, BUT WILL NOT DRAIN
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
