Question about E-Machines eMachines Monitor E15T4
Monitor on emachines computer is black and the on/off light flickers screen will not come on
  • 2,229 Answers
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Posted on Jan 22, 2009
5 Suggested Answers
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Posted on Aug 14, 2009
  • 1274 Answers
SOURCE: My flat screen Samsung monitor flickers on and off
or it could be the cable? if you have a different vga cable you can try that, if that's not the problem then it sounds like your lcd is possibly dying. you should also look at the pins on the vga connections and make sure none of them are bent
Posted on Oct 31, 2009
  • 80 Answers
SOURCE: Acer AL1916 Monitor went black and beeps
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
Follow the directions and good luck!
Posted on May 15, 2010
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
When powering up the monitor comes on,then flickers a little,then display goes black.can the e233h monitor be reset?
Probably not. This is most likely either a backlight going out, or an inverter board going bad, or other internal component (costs $100+ to replace by a professional). Not worth it to fix in most cases, unless you have an extended warranty, or a local repair shop with really good rates.
However, you can try another monitor cord (between monitor and computer; not likely to be the problem, but rarely can help). Flat screen (monitors/TVs/laptops) generally last 5+ years with average use, but I've seen them fail within 2 years (especially on laptop computers). In general, if you got 3 to 5 years out of a monitor, you did ok.
PS: If buying a new LCD monitor or TV, look for one that says "LED" on the box. (LCD monitors traditionally had a few fluorescent bulbs inside as "backlights", but newer LCD monitors/TVs have hundreds of tiny LED lights inside, which last longer, use slightly less electricity, and give more even lighting on the screen edges).
Dec 02, 2013 | eMachines E233H Bd 23" Widescreen Lcd
No picture screen remains black some flickering
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Blue light on/off switch to monitor flickers, but will not turn o
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors2.gif parts called capacitors overheat and blow out. You can go to our web site at: and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Corporate Computer
Sep 10, 2009 | E-Machines eMachines Monitor E15T4
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Emachine monitor flickers with horizontal lines
If you have another computer handy....hook the monitor up to it to see if the problem remains, if it does not you might want to focus on the video card.
Nov 03, 2007 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Monitor E15T4 Logo
280 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
