Question about Kenmore Elite 45986 Front Load Washer
Water is leaking from the door
There is a thin wire ring with a spring that attached the two ends. It seems that a a shirt sleave was caught between the door,because that shirt was wound very tightly. I don't know where this thin ring came from. or where to put it
  • 101 Answers
That ring goes around the front door boot. There is a black rubber seal that goes around the entire basket and door. That ring seals it. There is a small lip at the edge of the seal that the ring sits on. What you will want to do is put the ring around the seal and use needle nose pliers to stretch the spring attaching it to the other end. It is a pain to get it attached. After you attach it you will want to make sure you have a proper seal around it so feel around it making sure it is in that lip. If you have any other questions let me know and let me know if this was helpful for you. Good luck and I am glad I could help you out.
Posted on Jan 22, 2009
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Two problems: soap cover and seal?
Door leaked because of a plastic bearing ($4.10 part) on the lower arm causing water inside to surge and splash out the vents on the bottom of the door. Soap cover problem was a corroded spring caught on a plastic part inside the door panel. The spring actually broke and now seems to work fine because there was another spring helping to do the same job that is now allowed to work.
Dec 08, 2009 | Whirlpool DU943PWK - Multiple Color...
Water leaks out the bottom of door. metal ring with spring came off. put it back on and has leaked since I have the same problem. I went to get laundry out of the machine and there is plastic piece with...
This is boot retainer. DO NOT CONTINUE USING. If water gets on electrics it can be dangerous. Also may cause further damage. These sometimes come off if unit shakes too much. As in broken shocks.
Nov 05, 2007 | Washing Machines
I have the same problem. I went to get laundry out of the machine and there is plastic piece with coded wires attached and metal tension that appears to go around the drum hanging loose. Probably have water but the machine is in the basement not too far from the drain. Mine is a duet 9100L about 4 years old
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Problem hose
Try gently feeding a thin, springy wire down the tube to find is there is a blockage further up.
Mar 22, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Kenmore Elite 45986 Front Load Washer Logo
70 people viewed this question
Sal De
 Brian Main
Brian Main
