Question about Lexmark X5470 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
  • Lexmark Master
  • 684 Answers
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Posted on Jan 23, 2009
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Carrier Jam, there's nothing in it, I put new cartridge in still saids carrier jam, other then that this thin strip came out
The thin strip could be the encoder strip (transparent strip) which is responsible for the proper movement of the cartridge carrier along the carrier assembly. Please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X4650 InkJet Printer
When trying to print, it says I have a carrier Jam.
HI!! in your case my diagnose is that maybe the the incoder strip was defective and need to replace it.
Jul 12, 2009 | Lexmark P4350 All-In-One InkJet Printer
Carrier Jam(lexmark x5320)
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
My x5320 cant retrieve the application list im using windows xp media ed
Contact Lexmark tech support. They did a download for me because my x5320 is a 32 bit and my laptop is a 64 bit. It worked fine. they did the "let me drive" option.
Jun 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly installed won't stop jamming paper
Paper Jams in the Printer ID:412
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
If this didn't work please replace the printer by the company..
Apr 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Carrier jam
Do have a slamming noise.Then the encoder must be broken or it may displaced ..if its broken your printer is defective...
if out of place u can fix it Note:::::::::encoder strip is very delicate in process of trouble shooting it may get damaged so take extreme care please use this link to trouble shoot:::::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS22722&relevance=0
Mar 16, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
188 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
