Question about Topcon Gts-751 Long Range 1" Total Station 60554
How do I install the definition of a Total Station topcon 751 on Windows 7
I owned the original definition of the disk but does not respond to Windows 7
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
Download topcon link soft were
you will need to contact topcon this is a very bespoke item and its unlikley other drivers or sync tools will work and the link software may need to be licensed
Jun 11, 2014 | Topcon GTS-102N Total Station
Why GTS-102N can not read prism
These are actually high maintenance items and require periodic cleaning and calibration from the manufacturer or authorized service center.
Jun 08, 2014 | Topcon GTS-102N Total Station
Driver topcon link
I want Driver Topcon gts102n
May 29, 2014 | Topcon GTS-102N Total Station
Topcon total station gts 725
In windows 7, it is there. In explorer, put the name recycle bin in and it will show.
Apr 06, 2014 | HEWLETT-PACKARD Computers & Internet
I want a charger for my Nikon DTM-A20LG
If your DTM comes with a Li-ion battery, try this universal charger product - http://www.hahnel.ie/?page=chargers&pId=54
Feb 22, 2013 | Nikon Dtm-a20lg Total Station, Surveying,...
I'd like to know what means the error e-99of a line on myTopcon Gts-603 Total Station screen
I believe the GTS-6XX series is the non robotic version of the GTS-8XX series. And E-99 in the GTS-8XX series is when the station cannot write to it's internal memory. Try resetting it. If it comes up with the same error, the ABS circuit board needs to be replace. Unfortuinately parts have not been available for that unit for a long time.
Dec 26, 2012 | Topcon Gts-603 - 3" Total Station - Used
Locking mechanism for the topcon gts-3b total station isn't locking
The lock on almost any Digital Theodolite or non-robotic total staton is very similar. It's an rotating shaft with an side ways egg shape at the end. As you turn the knob the oblong end pushes on a pin or some sort of friction device that is attached to the axis. Often what will happen is either the position of the lock shaft moves, so it reaches a limit before enough friction is applied to the axis. Or some part of the lock is jammed and is not pushing into the axis.
It should be visible behind the display, and there should be 2 set screws on the bottom of the instrument below the lock (on the outside, not behind the screen) Most likely backing thoes off, just a little bit will give you enough movement to watch internally where you can find a new lock position, and tighen the setscrews again to hold it in place.
Jul 25, 2012 | Topcon Gts-3b 5" Total Station Theodolite...
I want a free driver for my topcon total station gts 105n model
Hi
For free driver and update the driver click hear and download this application. and injoy
Aug 11, 2011 | Computers & Internet
Topcon Gts-751 Long Range 1" Total Station 60554 Logo
132 people viewed this question
Top Topcon Electronics - Others Experts
Are you a Topcon Electronics - Other Expert? Answer questions, earn points and help others
