Question about Kenneth Cole All Brown Multifunction KC1436 Watch for Men
Crystal diameter Good day, This is my first time doing a watch repair project, and I am very excited. I own a Kenneth cole wrist watch (model number KC1436) and I'm trying to find a replacement wrist band and replacement crystal. The wrist band seems to be 24mm width, but I am unsure of the thickness. The crystal appears to be between 39 and 41 mm in diameter and 1mm thickness, but I would like to be sure. Please provide me with the correct dimensions for both the wrist band and the crystal and let me know if you have any recommendations for vendors to this sort of items. I look forward to hearing from you. Best, Louai
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
  • 2501 Answers
SOURCE: how do I set the time on a kenneth cole kc1296
I couldn't find any instructions for your watch but my wife has a similar one and it goes something like this.
There are two recessed buttons which need to be operated by a thin probe.
One of them is a "mode" button which changes the operation from normal to setting mode.
When you have pressed the mode button you should see the "hours" flashing use the other button to change the time (there may be two buttons, one up and the other down), when you ahve the right hour press the mode button again and the minutes will flash. Adjust as for the hours and when all is OK, press the mode button again to return to normal operations.
Good luck, have patience!
Posted on Mar 15, 2010
Need a link for band
  • The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
  • Hope this helps.
Nov 26, 2011 | Kenneth Cole KC3289 Wrist Watch
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
I am looking for a replacement band for a Kenneth Cole Reaction watch. The model number I believe is KC 1376 and there is another number P93-06. Any help would be great.
Thank you for contacting FixYa.<br /> According to previous customers on FixYa, Kenneth Cole are extremely hard to find and KC company has been of no help or assistance.<br /> I am afraid your best bet is going to be:<br /> <a href="http://www.watchbands.com/">http://www.watchbands.com/</a><br /> Good luck. <br /> Jewel<br /> Please be sure to rate me.
Aug 27, 2010 | Kenneth Cole 1213 Wrist Watch
I NEED A CRYSTAL FOR MY KENNETH COLE WATCH WITH THE NUMBER 954-01-KC1011 ON THE BACK OF THE CASE. CAN IT BE SENT DIRECTLY TO ME
The web site for KC watches is http://www.genevawatchgroup.com/ .
If you visit this site you will see "customer service" on the right. Clcik on this for service information.
Aug 04, 2010 | Kenneth Cole KC1104 Wrist Watch
I have a kenneth cole watch that needs a crystal and band replacement, where can i send it?
mcdevito75 here, Almost any jewelery, watch repair shop could help with a crystal and band adjustment. Look for the small watch repair shop in your area to save on cost.
Jun 18, 2010 | Kenneth Cole KC1104 Wrist Watch
Repair
We are located in the Holyoke Mall in Holyoke MA. Kenneth Cole crystals can be taken off. The crystal needs to be ordered.
Apr 10, 2008 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole KC3754
Oct 27, 2007 | Kenneth Cole KC1104 Wrist Watch
Watch crystal broken
You can send it to 47-50 33rd st. long island city ny 11101
Attn: repair dept.
before you send in please call 17187298600 X272
Thanks
Tsai
Apr 13, 2007 | Kenneth Cole KC4387 Wrist Watch
Watch problem
The rotating number is beneth the dome crystal, you CANNOT repair by yourself, you can send it to 47-50 33rd St.
Geneva watch group
Attn: Tsai
I will help you with this problem.
Thanks
Tsai
Feb 21, 2007 | Kenneth Cole KC3500 Wrist Watch
Kenneth Cole All Brown Multifunction KC1436 Watch for Men Logo
13 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
