Question about Krups XP 5280 Espresso Machine
Coffee button don't switch on - Krups XP 5280 Espresso Machine
I don't have a manula for my jwx31 and I can't set the timer
Do you have a "delay" button? Press that, a yellow LED should light, and you then set the start time. The manuals are all online, you know...derrrrrrrp!
Apr 09, 2013 | Mr. Coffee JWX31
When machine is turned on from the off position it does not go into rinse mode message comes up to hot please wait and yet the machine has been turned off for at least 20hrs
the power on sequence for the XP9000 is
1) Internal diagnostic
2) if no cold water, display notice and wait for water level in cold water tank
2) if water heating block is not hot, display notice and wait for block temperature
3) display "Rinse Press Hot Water" notice and wait for button press
4) rinse
5) display "Select Beverage" and wait for button press, ground coffee flap, or other input switch state change.etc...
in short... its doing what its supposed to.
Please consider reading the manual supplied wih your XP9000 or downloading the manual if you don't have it.
Nov 10, 2011 | Krups Super Automatic XP 9000 Espresso...
The machine don't give cup of coffee. ACL screen turn off with the message "not ready". The 3 selection's cup buttons are off. It seems that water does not heat.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101';
Sep 09, 2011 | Keurig B50 Coffee Maker
My machine wont give me much water into the brewgroup tried another brewgroup and it is the same . Iyt takes about a minute to put thru one shot of coffee and we only get about 10mm of expresso in the cup...
Hi
If you push the scoop but don't put any coffee in the brew group, what happens? If it brews right (water comes out), then I would suspect that your coffee is too fine. Push the lever below the grinder on the right to the back (#7) and then try to brew again. Don't let it go all the way. Push the coffee button as soon as it starts to brew. Do this 3 times. The 4th time let it go and see if it will brew. If it doesn't I would need more information.
Aug 10, 2011 | Saeco Royal Cappuccino Espresso Machine
Menu comes up...don't know what to do. Can't get it resest to make coffee. Don't care about setting times on it.
Here is a tip that I wrote about how to registeryour Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
KeurigRegistration, User Manuals, Cleaning, and Troubleshooting heatman101
Jun 24, 2011 | Keurig B60 Coffee Maker
Gaggia Titanium - the button for a small coffee has stopped working. Can I do anything to fix it?
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Jun 23, 2011 | Gaggia Titanium Espresso Machine
Can I put ground coffee directly into the brewer basket to make a cup of coffee? I don't have a coffee pod
Nope, don't put the ground coffee directly into it. Instead try using a Napkin or Paper towel.
A piece of cloth may also be used, but the paper towel is preferable.
Hope it works out!
May 31, 2011 | Vacuums
The coffee water does not exit from the filter basket. The lever the allows flow into the lid of the carafe when the carafe is in place does lower to allow flow. The blockage appears to be in a valve...
I have the same problem. It's now five months since you asked this question and you've not gotten a response. It doesn't look good for us. I removed that part of the filter basket. Maybe we don't need it. I'm going to try making coffee without it if we don't get an answer today.
Nov 18, 2010 | Krups Aroma Control 229 Coffee Maker
Krups XP 5280 Espresso Machine Logo
42 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
