Iq drive central unit od sensor fault
Od sensor fault
I HAVE A 2001 TRIUTE.IT WOULD NOT SHIFT INTO DRIVE BUT I COULD MANUALLY SHIFT AND IT WOULD WORK.ONCE IN DRIVE NO PROBLEM UNTILL I STOPPED.NOW MY OD LIGHT FLASHING
The first thing to do is change the transmission filter and fluid. This service should be done every 80,000 miles. If the OD light continues to flash after the filter service is done, then perform an OBDII scan of the stored fault history. Look for a transmission speed sensor fault. A bad speed sensor will result in no torque converter lock-up and no overdrive function. Also look for a bad torque converter lock-up solenoid fault. This solenoid can be replaced when accessing the trans filter (while the trans pan is off)
Aug 13, 2017 | Cars & Trucks
How can i fix this problem im having with my crown victoria 2005 my OD Overdrive blinking
The OD light is blinking because the transmission control module has detected a fault in the transmission operation, most common is slipping as measured by the input and output turbine shaft speed sensors. You may feel no slipping but the sensors are detecting it or one of the sensors is giving a fault signal.
Apr 06, 2016 | 2005 Ford Crown Victoria
What is the problem when on 2006 Ford expedition overdrive light flashes and will not shift out while driving?
run the fault codes to check for OD servo/solenoid problems or a problem TCM/ speed sensor unit.
Sep 08, 2014 | 2006 Ford Expedition
Will make dodge trans temp light o d off
Run fault codes and look for a servo/sensor fault in the od section of the box. If the od band/clutch is slipping it will cause the oil to over heat. Have a pressure test done on the box to ensure proper operating pressure. Check for correct oil level in the gear box.
Aug 17, 2013 | Cars & Trucks
Trying to locate plug-in on wiring to speeo sensor on 2007 polaris iq touring 600
The Input is there but you are receiving input voltage that is throwing off your gauge. That wire is what you need to find... Somewhere you need to find the chaffed wire
Mar 20, 2013 | Polaris 2007 IQ Touring 600 HO CFI
CD4E OD does not downshift out of gear when decelerating, OD light is now flashing, and I can no longer move in forward gears.
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 04, 2012 | Cars & Trucks
What are the electronic components of a fully automated washing machine?
Fill valves allow water into the machine.
Central control unit monitors soap levels, water temps,
Motor control unit operates the motor with signals from CCU.
Pump discharges the water.
The main faults being overuse of detergent and clogged filters.372aac7.jpg7a48b4d.jpga5e4e31.jpgRate it or hate it:
Jul 14, 2010 | Whirlpool Washing Machines
Whirlpool aws 3551 fault FO7
Hi
Fault F07 is a Motor Control Unit Error. It means that the Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. To resolve this issue you need to:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
  • Please revert for further assistance.
    Thanks
    Rylee
    Jul 25, 2009 | Whirlpool Washing Machines
    Fault F07
    F07 Motor control unit error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
    Potential Causes
    • Check the MCU
    Replace failed component.
    May 20, 2009 | Whirlpool LHW0050PQ Front Load Washer
    Heating & Cooling Logo
    35 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
