Question about Dishwashers
Water leaking underneath pitsos dishwasher when in use
When in use water leaking from underneath machine, have checked all internal filters
  • 17,129 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Posted on Jan 12, 2013
  • jeanhoward56
    jeanhoward56 Jan 14, 2013
    Thank you, after checking the hose/drain connections all now appears to be OK used the dishwasher twice now and no leaks.
  • 883 Answers
SOURCE: dishwasher leaking
You must remove all covers possible in order to watch the drip source using a flashlight. Once found, yes, the leak is fixable. All leaks are fixable...depends on cost of fix. A main pump seal repair/replace may be too expensive. Again, cost is the main factor. So find the leak, then get a repair estimate, if necessary...or get a screwdriver and tighten the hose clamp.
Posted on Jul 14, 2007
  • 105 Answers
SOURCE: leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Posted on Feb 02, 2008
zeusfaber
  • 247 Answers
SOURCE: smeg dishwasher
The second problem is almost certainly a symptom of the first - leaking water is reaching some of the electrical terminals and shorting them to earth.
First thing to do is to make sure the strainer in the bottom of the cabinet is clear - if it's really badly choked, you can brew up quite a spectacular flood.
After that, best I can suggest is to move the machine onto a piece of dry carpet, run it for a short while and see whereabouts the carpet gets wet first. Use this to guide your subsequent leak-hunting.
If there's any hint that the leak is from the front of the machine, check the seal between the lower edge of the door and the bottom of the washing chamber. On some machines, this gets covered with a thick layer of hardened grease (which is fine, until bits of the grease start to break off). If this is your problem, scrape the remaining gunge off, give the metal surface a good clean,and expect the last vestiges of the leak to cure over the next couple of washes as the seal recovers its proper shape.
Next thing to look for is the device which senses when the machine is full enough (and tells it to stop filling). Let the machine get to the stage when it is leaking nicely, then turn it off, open the door, and see if the cabinet has filled to overflowing. If it has, then drain it, then unplug the machine and take the back cover off. Look for a thin hose coming out the bottom of the washing chamber and running up to a small unit mounted on the case some way up with a pair of wires going to it. Check this hose for cuts, splits and blockage.
If the leak is coming from further back, then you are going to need to look inside to see how much of the inside of it is wet. Use this to guide you to where you need to do a more detailed inspection.
Check all the nearby hoses, looking for splits - especially where they push onto fittings, cuts (especially anywhere they're pulled over sharp edges) and just generally to see if they've pulled off completely.
Next, check any plastic fittings in the area to make sure they haven't cracked, and look to see if there's any evidence of water seeping out of the joints between the different fittings (in case you've blown an O ring, rotted a gasket away, or just had some screw work loose)
A.
Posted on Apr 13, 2008
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
  • 8 Answers
SOURCE: gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Posted on May 01, 2009
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Leaking water
Your waste pump might not be clearing the water from the machine. When you open the machine, is there a visible pool of water at the bottom? Check that your waste pipe isn't blocked, and check and clean the filter basket underneath the bottom dish tray.
Apr 04, 2009 | Dishwashers
Gld5860l00ss QuietPower2 water leak
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Leaking dishwasher
Feb 02, 2008 | Dishwashers
Dishwashers Logo
279 people viewed this question
Top Dishwashers Experts
Owen Barnes
