Question about Xerox Phaser 8200 Laser Printer
Xerox phaser 8200
When starting up, it goes up to print head test then goes to xerox screen and it hangs there. Tried reset and it just flashes grayish black. Flipped dip switch 1 & 2 and no luck. Help! This is for a K- 5 school and it is the only color printer they have. Thanks
    Problem Solver:
  • 15 Answers
Couple options, If printer will go into diagnostics mode take look at the print-head heater temps, if you cant get it into diagnostics, theres 2 posibilities, either the print-head has failed, or the Electronics module has failed, make sure printer is on its OWN DEDICATED POWER, NO EXTENSION CORDS, NO PLUG STRIPS and make sure its not sharing power with a coffee pot on the same curcuit. (or other power hungry office equiptment) If you get a Xerox Service pro on site he/she will probably have to plug a laptop into the engineering port to tell you whats wrong, if it cant be diagnosed from the front pannel.
Posted on Jan 23, 2009
Phaser 8200 won't start
First of all Printer's service
then see what is flashing in your printer's screen
Feb 14, 2014 | Xerox Phaser 8200 Laser Printer
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 will not start up
Are you getting any fault codes on the screes? A fairly long number..
Jul 29, 2008 | Xerox Phaser 8200 Laser Printer
Xerox 8200 Phaser color problems
Have you gone to and clicked Support and Drivers.
In the box that appears type Phaser 8200. The click the red drivers and downloads. Then scroll down and download the jet snipit files.
Then run it as the directions tell. It does a specific jet cleaning that may restore the blue.
Also have you tried to subsitute any jets? The jet substitution comes up in the remove light stripes area. There is a test pattern that prints out with the colors and jet numbers. You then substitute the jet number with the blank square.
You can try those, but with an 8200, I strongly suspect the only thing that is going to correct the problem you have it to replace the print head itself.
I will say also, that is a very expensive part.
The Phaser printers that are toner based now. They produce the best quality color print available. The toner particles on those now align, and are not just placed on the paper "close" to correct. They do it perfectly.
If exact and outstanding color is what your looking for I would look in that direction to be honest. A new print head for a 8200, is over $700.
Try the snippet cleaning, jet substitution and if those dont help, more than likely , I would say 98 percent chance your print head is needing repalced.
You indicated you used the different color settings. Does that include tek color correction?
At the site look into that under support. In the support area type in blue then follow the incorrect color items.
Wish I had an exact answer. In a way there is, but you have to try the snippit and substitution modes to verify the print head will not clean itself properly.
May 17, 2008 | Xerox Phaser 8200 Laser Printer
Color printing problem
Most likely the print head has failed.
May 06, 2008 | Xerox Phaser 8200 Laser Printer
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
