WHY IS THE WASHER MOTOR PRODUCING SPARKS
MY WASHING MACHINE RUNS FOR A VERY SHORT TIME WITH SPARKS BUT CAN'T SPINE,WHAT COULD BE THE PROBLEM
  • Washing Mach... Master
  • 17,129 Answers
Possible failure of the motor and so it must be shut down before it can become dangerous. If the sparks are seen to come from the inside of the motor it can be due to even water logging or a failed winding. Confirm and replace.
Posted on Jan 12, 2013
  • 97 Answers
SOURCE: water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
  • 121 Answers
SOURCE: servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Posted on Mar 03, 2008
SOURCE: washer not spining
I took the bottom panel off the washer. I don't know what i'm looking for?? Help!! The washer won't spin. the belt and motor are ok..
Posted on Sep 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washing machine stops and there is a burning smell
Your motor is tired.
Replace the motor or the washer.
Posted on Mar 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: Washing machine is not spining
Hi
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 01, 2009
Why my crosley washing machine model CAWS823JQO made loud nosie then stopped spining
Likely possibilities:
  1. Coupling between motor and transmission has broken.
  2. Transmission has failed.
Number 1 is cheap and relatively simple to replace. Tip the machine up in front and place a support under the front edge of the cabinet. Look for broken pieces on the floor. See if you can freely rotate the motor shaft without affecting the transmission shaft. Check that the transmission shaft can be turned by hand. If yes to both, replace the coupling. If it breaks again after a short time, transmission is likely bad
Number 2 is expensive and difficult. If the coupling's not broken and the motor is operational, OR the coupling breaks again after only a short time, then replace the transmission, or the whole machine entirely.
May 25, 2014 | Crosley CAWC529JQ Top Load Washer
Tip
Washer not spining Top Loader Part II
In this tip I will discuss tips towards checking the motor ,transimssion, and timer on Top load model washing machines. Please also see part 1 of washer not spining Top loader for more tips as well.
on Apr 28, 2011 | Washing Machines
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
The motor of my washing machine produces sparks and stops running before the whole process is complete and the spinnig process cant also take place,what could be the pro
Please check this link for tips, it can realted to water within or if the brushes are worn out if this the brush type motor.
check this link: motor
Jan 12, 2013 | Washing Machines
No spining no water out
check to see that the drain hose is not plugged. if it is not spinniong at all the drive belt may have snapped and you will need to replace it
Oct 23, 2009 | Whirlpool Washing Machines
Hi
Thanks
Rylee
Apr 01, 2009 | Admiral AW22 Top Load Washer
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
