No hot water
Have radiators on no hot water
  • Washing Mach... Master
  • 17,130 Answers
Possible failure of the heating element of the washer. You need to check the continuity of the heaters to confirm this case.
check this link: heating element
Posted on Jan 12, 2013
Top half or Radiator is hot while the bottom half remains cold . Is this normal
This can be due to one of a few different things...First of all, water flows from the engine to the bottom of the radiator, using the water pump and gravity, and the water returns from the radiator back into the engine on the top side.
Thermostat isn't opening...this causes the water / antifreeze to remain in the engine, and not flow through to the radiator. If the water / antifreeze gets hot enough, it should activate the thermostat and water should flow into the radiator through the bottom radiator hose.
The bottom radiator hose is either worn out (there is a spring inside the length of the bottom hose. it is there to keep the hose from collapsing under the suction pressure during normal use) If the hose feels spongy, soft, or shows signs of cracking, replace it.
The radiator may be clogged, preventing the water from flowing freely through all of the 'fins' in the grill section of the radiator. Hot water usually isn't just in the top section during a clogged radiator situation...
Jan 09, 2015 | Cars & Trucks
The radiator cap isn't getting hot and needs water to replaced frequently
radiator hose may be closing together after running for a while causing water to overflow to tank and ground
Jul 22, 2014 | 2001 Dodge Caravan
Is there hot water is radiators
Nope. In most newer cars it's special mixed coolant that is used.
May 11, 2014 | Cars & Trucks
Why does my coolant not get hot in radiator
Check that you have put the thermostat in the right way. The body part has to go towards the engine otherwise the hot water un the motor cannot get to the mechanism to open the valve and allow hot water to flow through the radiator
Feb 03, 2013 | Cars & Trucks
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
Have a 1993 toyota paseo it keeps running hot change out radiator and house it does not have a tremostate could that be making it run hot
An explanation of the cooling system.
You start your car, it is cold at first. The thermostat is shut. Car warms up and raises the temperature of the coolant in the engine block. Thermostat opens up. Water from the radiator (cool) is exchanged for water from the engine block (hot) The cool water causes the thermostat to shut. This traps the hot water in the radiator so that it can be cooled down. The cool water that was exchanged for the hot water, now becomes the hot water because it is in the engine block. It heats up until it's temperature causes the thermostat to open again, exchanging cool water for hot water. If you have no thermostat, then you will never hold water inside your radiator. You have to hold it there to allow it to cool off, then it becomes useful to cool your engine. So, yes put a thermostat back in it, and please vote as to whether this was helpful or not.
Nov 23, 2010 | 1993 Toyota Paseo
How do you drain radiator?
Draining water from your radiator? Take a look at the
bottom portion of your radiator and find a screwed plug.
Just unscrew this, and drain the water. Take care that
you do not do this while the engine is still hot, water coming out is HOT.
Oct 17, 2009 | 2005 Nissan Quest
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Running hot
Radiator Fan Control Relay Switch. I bet your electric fan doesn't run?
Dec 01, 2008 | 2002 Nissan Altima
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
