Question about Sony PlayStation Portable (PSP) Console
Psp e1000 recovery mode on boot - Sony PlayStation Portable (PSP) Console
  • 36 Answers
You may have to download the official firmware again via the USB cable from your PC or homebrew firmware with a pandora battery.
Posted on Jan 12, 2013
PSP E1000/STREET WHITE SCREEN
i have also the same problem with psp e1003. what is the connection of white display to the UMD, that the problem is with the lcd
Aug 09, 2012 | Sony PlayStation Portable (PSP) Console
Tip
PSP Firmware 3.71M33-2 Diagram installation.
This article will explain a diagram of PSP CFw 3.71 installation. I have provided this document as a guide to helps PSP Users get started for installation CFw 3.71M33-2 with 1.50 kernel Addon2 on both PSP, Fat and Slims. here's a simple steps to find out.
Q:How do I know what version of the firmware I have?
A:Follow this, <b>Version check :</b> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP.
Q:How do I boot into "Recovery Mode",?
A:Do a full turn off (hold power button >5sec) and hold the "R-trigger" while turn on the psp.
Q:How do I know what kernel of game folder configured.?
A:Do this via "Recovery Mode" >> "Configuration" >> "game folder homebrew (currently: 3.xx kernel)"
Q:How do I activated the plugin No-UMD of CFw M33.?
A:Do this via "Recovery Mode" >> "Configuration" >> "UMD Mode" >> Select currently : "M33 Driver - No UMD". Any 4 option umd mode you can select, we recommended to select "Sony NP9660" for most games compatibles.
Q:I getting a blank screen/BSOD when booting my PSP, after downgrading my psp with pandora's?
A:Press "Bright" button on PSP, You will get a message for telling You to press "Circle" (O). Do it, and reenter your settings. Reboot your PSP if necessary.
Source : http://e-arena.blogspot.com/2007/11/psp-firmware-371m33-2-diagram.html
Hopefully this helps..!
on Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Only green led and not booting psp 1004
Disconnect the battery, reconnect and switch it on whilst holding down both top two corner clear buttons. It should restart in recovery mode. Toggle down and select RECOVERY folder, then select. If this folder is corrupted you will have to get a copy off of the internet and replace it using the usb connector. This usually does the trick, if it will not start in recovery mode, it's a SONY job..
Good luck
Jun 25, 2012 | Sony PlayStation Portable (PSP) Console
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
My umd icon is not showing up how do i fix it
Hi there. Try doing this;
1. Turn off your PSP (long press switch). 2. Press and hold "R" while switching on your PSP and you'll boot into Recovery Menu 3. Scroll down to "UMD Mode" and press "X" until the value changes to "S0NY NP9600" 4. Go back and exit to boot your PSP in game mode...
I hope this helped...
Jun 08, 2011 | Sony PlayStation Portable (PSP) Console
Psp power indicater lights up green but does no turn on.
Hi.
It's probably bricked (dead). We need to know what's your last activity before it bricked. Mostly, bricked PSP is due to interruption during firmware update. Or when you install a CFW (Customized Firmware) by using ChickHen.
If your PSP is the slim type, you need to know what type of Motherboard it has. You will be lucky if you don't have a PSP with TA088v3 MoBo. Since you can no longer turn on your PSP, you will have no chance knowing the MoBo. But this procedure below is worth the try;
1.) Turn off your PSP by pressing the power button at least 10 seconds and green light is gone. 2.) While turned off, do one of the following until you boot into Recovery Mode;
a.) press the "R" button and hold it while pressing the power button. b.) press both "L" and "R" button and hold it while pressing the power button.
3.) If you are successful booting your PSP into recovery mode, google on how to recover your flash0 file...
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
When i try to play soul calibyr broken destiny, it says something like, "game cannot be started (FFFFFFF8)
Are you using a modded PSP? If so, try the following.
The steps below fixed this issue that a user like yourself was having on his PSP.
Enable EBOOT.BIN in recovery mode. This is how you do it:
  1. Go to the recovery menu by turning your PSP off and powering it back up while holding the R-trigger
  2. Go to Advanced -> Advanced Configuration
  3. Set the value for Excute BOOT.BIN in UMD / ISO to Enabled
  4. Exit recovery mode and start the game
Regards,
G33k
May 11, 2011 | Computers & Internet
Hi The UMD icon is not showing on the PSP screen. Please help
Boot into recovery mode ((Via R button while turning PSP on after a hard boot.))
Go to "Configuration > UMD Mode: Sony NP9660.
Should work.
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
How to access psp 300 6.20 version recovery mode
If you are running CFW ver of 6.20 Reboot the psp and hold the R button down while booting up.
Mar 04, 2011 | Sony PlayStation Portable (PSP) Console
Dpfmate program will not run
try restarting u computer. or try going into ur recovery menue by presing select and prsing restart and holding the R button when it boots up again it usb mode see if u can access it like that. (dDONT MESS WITH ANYTHING IN THE RECOVERY MENUE JUST USE THE USB MODE ON IT)
Jun 23, 2009 | Bandai Digital Entertainment NARUTO -...
Sony PlayStation Portable (PSP) Console Logo
197 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
