Question about Kitchen Ranges
Glowworm flexicom hx18 f1 fault ?
The boiler keeps going to f1 or f4 it was on through the night but has gone off now and wont fire up!!!
  • 213 Answers
SOURCE: Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Posted on Nov 27, 2007
  • 171 Answers
SOURCE: how do i servis a glowworm compact boiler
Hi, perrycallow,
I'm Harvey the Master Plumber,
You want to know how to service a Glowworm compact boiler
Glowworm is a United Kingdom company and here is the information you asked me for, to get their technical service line:
Technical Help: 01773 828300
technical@glow-worm.co.uk
Thank You,
Harvey your Master Plumber.
Please give me a good rating before you sign off.
Posted on Sep 09, 2008
SOURCE: fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Posted on Dec 01, 2008
shastalaker7
  • 1515 Answers
SOURCE: F4 fault with Vizo Plus 24. Not condensation tube
Hi, if the ignition module fires or tries to fire 4 times, this indicates the module is faulty and locks out for safety reasons because of an internal fault.The f-4 code sounds like the pressure switch was open due to condensation not letting it fire up, so the switch was ok, so they changed out the tubing. When you re-set the boiler control module, it locks out due to a internal fault. Change it out and you will be back up and running. The electrodes from the module will cause this as they come from the module. Make sure the condensate trap has no blockage at all as this can cause this problem. I am not guessing, I would replace the boiler module control that you have been re-setting. Keep me posted,
Sincerely,
Shastalaker7
Posted on Mar 19, 2010
  • 2597 Answers
SOURCE: valliant combi boiler Fault Code F1 What does it
f1 means failed to fire check you have gas to bolirt and check water leval on boiler 1.5 bar
Posted on Aug 11, 2010
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
How do I fix a fault
Not a problem. I have noted that the F4 Ignition fault you are getting is with a Glowworm 18si boiler.
This relates to the burner system and will need a gas licensed technician to fix it.
I am providing you reference to an Installation and service manual to help you understand the likely fault but under no circumstances is this an invitation to attempt to fix the fault unless you are a qualified gas technician. Refer page 37 in the manual.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/24ci-18si.pdf
Aug 13, 2014 | Dishwashers
How do I use the analogue glide down timer
1) Copy following link for setting analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/pdf/Glowworm-flexcom-analog-timer-manual.pdf
2) Add a comment Dec 2012 for additional information.
Dec 12, 2012 | Hardware & Accessories
Glowworm 24hxi combi boiler fault codes
it's an ignition fault (lockout) failed to light.
cause:
no gas
insufficient gas
incorrect gas valve adjustment
electrode ignition lead defective
electric igniter defective
check air inlet duct
check connections to igniter unit.
most common cause is igniter is defective (looks like a spark plug)
if you can hear a clicking when boiler goes to ignite, then it will be igniter at fault (no spark), check lead going to igniter (for any deterioration, looks like a ht lead). if all ok. change igniter.
hope this helps?
Jan 22, 2012 | Kitchen Ranges
F5 keeps coming up on my boiler when i turn it on could you tell me what F5 means please
Who is the maker of your boiler? Also, I need a model number so I can look up the info.
Dec 12, 2010 | Heating & Cooling
Valliant combi boiler Fault Code F1 What does it mean
Aug 09, 2010 | Heating & Cooling
F4 fault with Vizo Plus 24. Not condensation tube as this was changed to new tube with sensors on ''blue plug'' by engineer last year when I called them out for re-curring F4 fault - new sensors are bone...
Sincerely,
Shastalaker7
Mar 18, 2010 | Heating & Cooling
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
How do i servis a glowworm compact boiler
Hi, perrycallow,
Thank You,
Sep 06, 2008 | Water Heaters
Glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Dec 14, 2007 | Desa International GWP20T GLOWARM Wall...
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
