I have a Visonic Powermax and we have it install in our Church however the member that installed it no longer attends our Church and I need to reset the Installer code so that I can conduct tests and add new sensors.
To reset the Visonic Powermax installers code to 9999
The User Code 1 will also be reset to 1111
Unplug the ac transformer and disconnect the main units back up
battery then flip it over and find the pins labeled "DEF" on the
circuit board. Lower right side of circuit board.
You'll need to short the two pins closest to the bottom of the powermax+ unit labeled DEF,a metal paper clip works just fine.
Have someone plug in the ac transformer while holding the short.Hold
this for 10 seconds then unplug the transformer before removing the
short.
Remove the short and turn the unit over, plug it back in and try 9999 as the Installer's Code.
(If the reset did not work the first time, try again making sure the
short between the def points remains closed during the 10 second power
up.)
Hello Dear friends I am a cafe owner.I have 35 pc in cafe.My problem about lost connection of...
(More)
Hello Dear friends I am a cafe owner.I have 35 pc in cafe.My problem about lost connection of internet but modem leds are not turn off when disconnected.they stays on.We are using Adsl connection and we are using Eset Nod32 antivirus program is licensed and updated.What do you think about this problem. I scanned all cafe with 3 differ trojen scanner and antivirus. Network switches may cause problem? When the connection lost,sometimes i cant enter modem interface is 192.168.2.1 i use airties rt-111 and tried 2nd modem airties rt-102 Icant solve this problem.Pls help me about this.
I have a Linksys BEFSR11 and it throttles my download and upload speeds with Comcast. Other routers...
(More)
I have a Linksys BEFSR11 and it throttles my download and upload speeds with Comcast. Other routers with the same setting give me the full 20 gigabit speed, but the BEFSR11 and BEFSR41 throttle me at 6 gigabit.
I cannot access my mail @ Websteranna7@yahoo.com. It asked me to change my password and I did this,...
(More)
I cannot access my mail @ Websteranna7@yahoo.com. It asked me to change my password and I did this, but I still cannot open it.
