Question about Hotpoint Ultima WDM73 Front Load Washer / Dryer
Hotpoint wd420 washer dryer door won't open.
I had a wash on when the power cut out. i turned the power back on and finished the cycle but since then the door will not open. the light says door locked and it will not open. i have tried every different cycle and have also tried disconnecting the power for over an hour to no avail.
please help me as i am desperate to do another wash. thank you, jay
  • Hotpoint Master
  • 3,463 Answers
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Posted on Jan 23, 2009
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My aqurius WD420 shows that the door is locked. So i can't open it........
If the door will not open normally, then the only solution is to remove the top cover, and force the door open from inside the washer at the front
Jan 17, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
WD420 hotpoint door will not open ?
In some cases switching off and back on again solves it. Otherwise try to run Rinse & Spin cycle again, and if after cycle door will stay locked you'll need to check the door lock itself, its wiring and/or main PWB
Please Update me how is it going on this
Mar 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
1,648 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
