Question about Acer Aspire One Netbook 8.9" Notebook
Im trying to connect my acer aspire one to my tower via a data cable, although the two acknowledge that the other is there, they do not connect. i have been told that i need to give them ip numbers or something. can anyone help pls?
  • 520 Answers
You need ip's if you do it wireless ....
with cable you need to provide software for both units (which u create using networking in control panel)
a source ware is created on a disk ...
1 unit host other unit guest.
Posted on Jan 30, 2009
Can i factory reset it and windows 7 still be on there
If you do a Full Factory Recovery all your data will be lost, You will find a folder, Windows.old, that will have some data. Your machine will return to the day it came out-of-the-box and requiring you to do ALL updates and reinstall ALL software YOU installed. See: http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Feb 01, 2013 | Acer Aspire Ax1430g-uw30p Amd E-450...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    No signal to monitor
    Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
    May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
    How to connect My Acer Aspire One PC Notebook with Dolpin 3G SIM Card
    to connect it to your system some basic needs r use it in phone via data cable or use pc suite of phone or there is 3g stick available in market in which u can insert your sim and connect to your system
    hoping this will help u.thnx
    Jan 04, 2011 | Acer Aspire One PC Notebook
    I HAVE CONNECTED MY ACER ASPIRE PC TO MY SAMSUNG LCDTV USING A VGA CABLE , THE PICTURE IS THERE , BUT I CANT GET ANY SOUND ?
    The VGA cable only supplies video data to the LCD TV. Connect a sound cable from the audio out from the Acer PC to the audio input on the LCD TV to get sound from the LCD TV's speakers.
    Dec 14, 2010 | Computers & Internet
    I have acer aspire series computer for 2 years.one day when i open my computer my monitor display no signal what are the reasons
    Hi! it means that the monitor is not picking any signal from the tower or computer.Check all physical cables first esp the video cable from the monitor to the tower.Check if the computer has power by checking lights, sound coming of the machine. Check if monitor cable is securely plugged in to the vga or hdmi port.If you are using a adapter for that cable try to directly plugin the cable without using the adapter.If still no signal, check if you have a external video card or internal.if you have a external video card and thats the one that youre using then remove the external video card(you need to open up the tower and physically remove the external video card) and connect the video cable to the onboard card then check if will get a signal.hope this helps...
    May 20, 2010 | Computers & Internet
    Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
    i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
    I made various test:
    cpu (pentiun e2180) pass the test mounted on another PC.
    I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
    Some of this Acer model have this motherboard crash
    look also here
    http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
    http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
    http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
    http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
    Change the MotheBoard
    Mar 10, 2010 | Acer Aspire M1640 Refurbished Intel...
    Im trying to hook up my acer aspire one to tv via vga cable but cant seem to get it right.....any one know what to do?
    after you hook it up try holding the fn key and pressing f5... this should work... hope it helps...
    Feb 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
    Connecting my acer aspire 5100/5102 to my tv via cable
    There are a number of possible ways to getbthe display up onto your television. Im not certain which colours to use with which but once its all plugged in you will need to hold down the FN (funtion) key and press one of the F1-F12 buttons. to work out which one you just need to look for a button that looks like a screen or two screens and that should make the display external. good luck
    Feb 07, 2008 | Acer Aspire 5102WLMi Notebook
    Acer Aspire One Netbook 8.9" Notebook Logo
    Brian Sullivan
    Brian Sullivan
    Mohammed Ebrahim M
    Mohammed Ebrahim M
