Can't get my power washer to start sounds like there is no gas going thru the carburator and don't know if the spring is on its right place????
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Your throttle is at idle when it touches the tiny adjustment screw,set your spring so that throttle is constantly being pulled toward that screw.Now fill with gas,close choke,pump primer bulb a few times and let her rip
Posted on Jan 12, 2013
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
When I start my pressure washer on full choke it works fine when I place choke in wide open position gas runs out of the carburetor.what could be wrong.the engine issas by Briggs and Stratton.
You need to take the float bowl off the carb from the bottom . You haven't given a lot of information about who did what to the carburator but somebody must have screwed with the float pisition for this to be happening . The way all carburtors work is the same you have the float bowl and the floats and on top of the floats is a valve called the needle valve. Now the neddle valve is there to stop the flow of fuel into the float bowl when the engine is not in a high damand cycle for fuel like start up or ideal the choke shuts the air off and gives more fuel at start up .However when the engine is running and the float bowl is being filled by gravity feed from the gas tank the floats will move up do to the amount of fuel in the float bowl and should shut the fuel from the gas tank off to the float bowl until the engine can burn the fuel and drop the float level enough to make the neddle valve open again to supply more fuel for the engine to run correctly its a never ending cycle . You need to adjust the floats and likely clean the carburator don't mess with adjustments there mostly automatic when the engine is running
Sep 16, 2011 | Simpson WS4050V Water Shotgun 4000 Psi...
Put a new carburator on and don't know how to hook
Hi janemueller...
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Free answer...Please take time to rate me
Jun 15, 2011 | Poulan Garden
My car cuts out when i take my foot off the accelerator. Sometimes its fine for a while, other times it wont even start. When it has cut out it is normally hard to get her started again.
have you service your carburator lately?? carburators get dirty more easyly than you think, so it sounds like if you have a dirty carburator, it is a little bit complicated to do the tune up, so i recomends you to take it to a local shop to have them take it a part clean it and replace all the adjustment screws, springs, plugs and gaskets, or if you live in the US and want to do it your self (wich you had to have good skills) go to www.carburetorfactory.com and get a rebulding kit, other wise if you don´t want to spend to much money let me know what kind of engine do you have on your car and i can find you a viedo guide to try to fix your problem, hope this helps.
Dec 21, 2010 | 1988 Volkswagen Fox
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Where is fuel filTER
Hi:
There is only one line (tube) that goes from the gas tank to the carb. If there is a fuel filter it will be on that line. To check if it is plugged just pull the line off where it attaches to the carb. If you spill gas, that is not the problem. Replace the line and be sure to clean up the gas. Sounds to me like a carburetor problem, though.
Jun 30, 2009 | Karcher Quick Connect Nozzle Set
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Not starting
could be stuck float tap on carb with a small piece of wood and see if gas flow stops , if so add fuel conditioner and try again
Dec 09, 2008 | Garden
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
