The washer drains but does not spine
IT DRAINS BUT DOES NOT SPIN OR WASH
    Problem Solver:
  • 5 Answers
Sounds like a PCB fault, you should look at getting the board checked.
Thanks
www.recycledrum.com
Posted on Jan 12, 2013
  • Washing Mach... Master
  • 17,130 Answers
If the washer does not wash or spin , it means that the main motor is not working. check the cycle to see if the inlet opens to fill water to the drum , If so check the voltage to the motor when the water level is reached., If absent then it can be failure of the main motor assembly.
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
SOURCE: Washer fills and drains but won't aggitate or spin
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Posted on Apr 10, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
Maytag317
  • 1136 Answers
SOURCE: Maytag PAV2300 - Washer agitates during wash. on
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Sep 13, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Washer does not go through the spin cycle
while the machine is empty and in the spin cycle open the lid and hold down the lid switch spin the basket with your hand if it spins slowly you probably have a worn out clutch.
Jul 15, 2012 | Washing Machines
I have a bosch 300 series front load washer that wont spine it fills and drains fine belt is on what could it be
If it doesnt wash either, the brushes will possibly be the problem. You need to remove them and check the length.
Aug 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My washer when it is in the wash cycle will stop at 1/2 way and not drain, spin or rinse. Could it be the timer? If I turn the knob manually I can get it to finish the cycle.
If you can manually turn the timer to spin and it drains and spins it is a bad timer.
If it drains only and does not spin it is a bad lid switch.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer won't spin
This should help you get to the coupler between the motor and the trans.
Good Luck
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Kenmore 22422 not draining or spining
Misti, usually no spin, no drain is a broken lid switch. part #3949238. See if the switch is busted off from the screws. Catriver
Dec 26, 2007 | Kenmore 22422 Top Load Washer
My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Jun 02, 2006 | GE WSM2700D Top Load Stacked Washer /...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
