Question about Pool & Spa
I have a Hurlcon VX - S series salt chlorinator that keeps switching itself from pool mode to spa mode which drops the chlorine output.
The system is controlled by an inbuilt timmer and is set for two 4 hour sessoins per day. Sometimes when you manually change back to pool mode it switches itsel to spa mode minutes later.
  • 272 Answers
SOURCE: no chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Posted on Jun 01, 2009
SOURCE: I have an intex salt water chlorinator and I have
Here is the website for all manuals! http://www.intexstore.com/default.aspx
All are dowloadable. Good luck!
Posted on Jun 23, 2009
  • 10 Answers
SOURCE: Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Posted on Jul 06, 2009
  • 297 Answers
SOURCE: My chlorine generater appears to be working fine
no chemicals needed -Test strip are not as accurate as liquid kits buy one for about 10 dollars
Also since it is a new set up you shouls run the chlorine generator for at least 8 hours.
Make sure your chlorine light comes on ( about 5 minutes sometimes a little longer after you set the timer)
Also get a test kit to detect salt 10 dollars for 10 tests Keep it as close to 3000ppm as you can the higher you go past this amount the saltier the water can taste
do not go below 2500 you do not want to have to be bothered adding salt for splash out or rain.
starting at 3000ppm gives you a long time before needing to add for the splash out or rain with these factors you only loose about 25-35ppm's when refilling and so on so it is a long way to 2500
One other pointer is to make sure you filter your pool enough. It is recommended to turn your pool water over at least 3 times a day
as an example I will use my 7000gallon pool with my 2000gl pump thats about 10 hours a day just for filtering. This does not include how long you need to leave the generator on to produce the amount of chlorine to produce a 1.0 or a 1.5 setting Also keep in mind that chlorine affects the ph so chlorine needs sel first before you worry about ph so once both are set then watch as the chlorine drops so will ph but once you run the generator to rebuild the chlorine level the ph will come up by itself. Ph will cause more problems with eye irritation and cloudy water than chlorine
Posted on Jul 12, 2009
  • 297 Answers
SOURCE: i have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Water is clear but chlorine and copper still low, what I need to do?
The salt generator only works when the pool pump is running. If you want a higher chlorine level, run the pump longer. Also, to keep your chlorine in the pool, be sure to adjust the stabilizer level. (25 ppm for salt systems). As for copper, this level should be 0 at all times
Jul 19, 2014 | Intex Krystal Clear Saltwater System Pool...
Tip
Solving Salt Water Pool Problems
The big problems with salt water pools is actually the salt in the pool water itself. Salt water chlorination has many benefits over standard pool chlorination methods, but with a salt in the pool system there are significant drawbacks, hidden expenses, problems, and potential dangers. The best way to enjoy salt chlorination is to get the salt out of the pool. The Chlorine Genie Pool Water Management System does just that. In fact the system can produce and take care of up to 5 important pool chemicals for you. If you are fed up with salt water pool problems and ready for the cutting edge in pool water sanitation, check out the new advantages of Chlorine Genie's Chlorine Generator Technology.
Chlorine Genie Inc Martinez 94553 The Ultimate Pool Chlorinator
Check out the Pool System Videos on YouTube at: Chlorine Genie
Get Social and Join the Pool Party at: https://about.me/chlorinegenie Chlorine Genie on about me
on Nov 08, 2016 | Pool & Spa
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
Vx salt chlorinator has suddenly stopped working fully, when on manually it just stays in sanitising mode. Every thing is fine chemical wise and pool level but output of chlorine is not happening
look for corroded valving or white powdery residue thatgs got the piping/hardware plugged up..may need replaced if you cant brush it off..
Jan 06, 2014 | Pool & Spa
How do you shock a saltwater system above ground pool
shock with chlorine until chlorine shows as free then let chlorinator take over or use non chlorine shock but that will lower your PH keep and eye on it
Nov 05, 2013 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
141 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
