The motor of my washing machine produces sparks and stops running before the whole process is complete and the spinnig process cant also take place,what could be the pro
The motor starts and runs for a very short time as it produces sparks, the spinning process can not be accomplished as well, what could be the problem? the INLET and DRAIN pumps are working well
    Problem Solver:
  • 5 Answers
This is a common problem when your motor brushes are worn. You can get cheap replacements on ebay.
Posted on Jan 12, 2013
  • Washing Mach... Master
  • 17,129 Answers
Please check this link for tips, it can realted to water within or if the brushes are worn out if this the brush type motor.
check this link: motor
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
  • 3230 Answers
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Posted on Mar 28, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
  • 21 Answers
SOURCE: unit runs good through wash cycle then while in
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Posted on Feb 14, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
WHY IS THE WASHER MOTOR PRODUCING SPARKS
Possible failure of the motor and so it must be shut down before it can become dangerous. If the sparks are seen to come from the inside of the motor it can be due to even water logging or a failed winding. Confirm and replace.
Jan 12, 2013 | Washing Machines
My duet washer just stopped spinnig
Your belt is disengaged or broken. You still hear the motor and if you do then it is the belt. Go and open the back panel of the machine and see if you can find out about the belt. Remember to be safe at all times. Good Luck
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool gsx988jq0 and wanted to know it is a belt drive or direct drive,because it spins and stops spinnig and makes a big pounding noise
Hi type washing machine does not unite Pelt
There Kepler
Between the motor and Transemsin and change will find it very easy
D & L in stor
Nov 22, 2010 | Whirlpool GSX9885J Top Load Washer
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
