Epson workforce 645 printing one blank page after another
Started to print and the printer started shooting out page after page,part of the time with nothing printed on them. I turned it off, and back on, and it kept putting out papers.I finally punched the reset button,and that ended that. Now it will not do any thing.
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
Inky
  • 691 Answers
SOURCE: Epson C88 printer only prints blank pages
See my post about about underhead cleaning. If that makes no difference you will need the countermeasure for the split cap tube. The document about loss of ink on CX series machines is also applicable to C88
Posted on Jul 18, 2008
PeteG0429
  • 34 Answers
SOURCE: prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
SOURCE: epson photo stylus R230 prints blank
aw mgkanu ang mainboard ng r230 at san nakakabili neto
Posted on Feb 11, 2010
Epson workforce 325 printing blank with black ink
The print head is plugged up. Try the nozzle check function or the clean function on the control panel.
Oct 07, 2016 | Epson WorkForce 325 Inkjet Multifunction...
Why does my printer sudenly print the wrong way across the page?
Sounds like someone changed the page orientation from portrait to landscape. Go to print preview before you print your next article and then go to printer properties and see how the page orientation is set.
Jun 08, 2015 | Epson Workforce 645 4x Ink MFC
Why does epson workforce 635 print emails in red
Hi Sal Lentz, try this:
1. Copy the message to word pad and print, if ok.
2. Check the printer properties from your web page.
Aug 21, 2014 | Office Equipment & Supplies
Epson workforce 520 printer won't print wirelessly
Reinstall the software until you get it right. I had to do it 3 times before it printed a test page. My error for not taking my time.
Feb 09, 2014 | Epson Workforce 520 Printer
Epson workforce 545 is printing & coping blank
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 18, 2013 | Office Equipment & Supplies
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
My epson workforce 600 printing blank pages.
Try print head cleaning several times(3-4 times). Print nozzle check to see results. If the same problem-contact SC for deep cleaning.
Jan 02, 2011 | Epson WorkForce 600 All-In-One InkJet...
My epson workforce 600 is printing blank pages
Do a nozzle check and see what comes out.It should be under a maintenance tab on the front control panel LCD.If nothing comes out it more than likely has not been used in awhile and the head needs cleaning.If this is the case and you get it to print again do a sample page at least once a week to stop this from occurring again.
Jun 19, 2009 | Epson WorkForce 600 All-In-One InkJet...
311 people viewed this question
k24674
jasbo
jasbo
