Question about Vacuums
Honest Star M-288 (robovac) stops running.
The vaccuum stops running after 30 or so seconds. I have tried cleaning it out, though I lost my manual for how to take it apart. Tried to get one thru the manufacturer, but they are in China and not very helpful. Anyone know where to find a PDF manual or any idea why it stops working after a few seconds even after I clean it?
5 Suggested Answers
SOURCE: Dyson DC07
http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
Posted on Mar 19, 2008
SOURCE: Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Posted on Dec 30, 2008
  • 61 Answers
SOURCE: Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
Posted on May 13, 2009
louislevel_2
  • 374 Answers
SOURCE: The brush stopped spinning on my Dyson upright
hi there'
common possible defective is that motor is not functioning,several factors can be check if you have a knowledge on electrical and motor
circuit you can easily diagnose your problem on your vacuum.
check the switch by your multi tester,if there is a continuinity resistance using multi tester.if no continuity replaced switch
check the carbon brush of the motor if worn out, replace two pcs. of carbon mounted inside the motor casing
you can check also the continuity of electrical cord and plug.replace if if plug and electrical cord is defective.
finally the motor has winding coil,at both end of coil of motor check the continuity,there are two coils of the motor.if burn out replace motor w/ two pcs. of carbon brush.
besure to unplug the vacuum before doing
this and this should be done by qualified technician on your service center.have a nice day.rate my fix.thank's a lot
Posted on Jun 11, 2009
  • 9 Answers
SOURCE: Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Posted on Jun 18, 2009
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Mar 30, 2015 | Dyson DC35 Handheld Vacuum
LG robovac stops
change belt
Dec 26, 2013 | LG Vacuums
May 13, 2009 | iRobot 4150 Roomba Vacuum
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Possible reset on Thermal Cut-Off
This is not really expert advise but I have a vaccuum with hepa filters and if the filters get dirty My vaccuum acts like your what you are describing.
Jan 07, 2009 | Eureka Vacuums
Hoover Wind Tunnel bagless- issue with turning on
Have you tried to plug the vaccuum in another outlet that is on another breaker? It could be the vaccuum tripped the breaker. Turn the breaker back on. The manual mentions the thermal protector could have been activated. If this happened it resets and your vac should run after 30 minutes. I have a Widepath Tempo and it has tripped the surge protector. If this is the problem try turning some things off that are also on that breaker/outlet, or unplug them when you use the vac.
Jan 04, 2009 | Hoover U6630-900 WindTunnel Bagless...
Accessory hose not sucking
Try taking the hose off, and making sure it is not stopped up, either in the hose, or where it attaches. Straighten a wire coat hanger and run down the hose to check for obstructions.
Hope this helps!!!
chad
Oct 08, 2008 | Dyson DC14 All floors Bagless Upright...
Dyson vacuum
there is some thing broken it is two plastic cogs they help the front go down and stay up you will have to get a star screw driver and there should be two screws on top and two at the bottom when you have undone them all you will see what i mean take them out only if there broken if there ok put them back in place and put the top and bottom back together if there broken get new ones or put in back together and you will have to lean it up all the time if you want new ones go to www.ebay.co.uk or .com don't for get to wright down your model number its much easy good luck
Dec 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vaccuum stopped running
Belt jumped off beater bar and jammed it! Disconnect belt, does imotor run. If yes, reconnect belt turning beater bar by hand to see if it is smooth. Carefully, reassemble and run it!
May 28, 2007 | Eureka 4386AT Upright Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
