Question about Turbos, Nitrous, Superchargers for Ford Futura
Power window
The power window (drivers side) problem is the cable appears to be not connected as the motor works (up / dwn) a photo of the mechanics would be great as i cant see behind the panel thanks in advance
    Champion:
    Scholar:
  • 227 Answers
Replace the regulator, not worth repairing.
Posted on Oct 31, 2013
2007 crown victoria driver side window wont go up or down what's the problem ?
if it is electric window check fuse box or the window motor or the connections or switch
Jan 24, 2016 | Cars & Trucks
Electric window (driver side) works, but why not the other three?
Power Windows Not Working - Repair Power Windows
www.popularmechanics.com/cars/how-to/a69/1272371/
Another toll-booth, another mile--or at least it seems as if the tollbooths come every ... The most common power window mechanism is pretty basic. ... If the driver's door switch won't open the right rear door, but the switch in the ... direct from the battery positive terminal to the positive side of the motor to see if it comes alive.
Power Windows not working - CarGurus
www.cargurus.com > Questions > Honda > Accord
CarGurusOct 9, 2012 - I have a 2007 Honda Accord the driverside window works but other 3windows dont, but when u hit the master switch on drivers door to try to ...
I can only operate one of three power windows - CarGurus
www.cargurus.com > Questions > Chevrolet > Prizm
CarGurusApr 28, 2013 - Drivers side power window works only. Had a mechanic ... windowsnot working either. ... Already replaced it. all switches showing getting power but don'twork. ... Are you certain that the other three window motors are good?
Why Do My Power Windows Sometimes Stop Working ...
Dec 21, 2015 | Cars & Trucks
My power window on the driver side wont go up or dwn but the other 3 switches on the driver panel work what could be the problem.
my power window on the diver side wont go up or down but the other 3 switches on the driver panel work what could be the problem
Sep 17, 2011 | 2006 Dodge Stratus
1999 z24 chevy cavalier power windows. drivers side window will not go back up, this had happened a few times. i checked that the battery cables are tight, and checked the fuse for the power windows....
You are experiencing the beginning stages of a failing window motor. If you've checked all the wiring, and it goes down with ease, but you need to "help" the window back UP, then you will need to replace the motor that drives the window to go up and down. Easily doable if you are even just slightly mechanically inclined.
Dec 13, 2017 | Chevrolet Cavalier Cars & Trucks
Driver's side power window will not come back up
it could be the Electric window motor or possibly the mechanism that operates the window as these days a lot of the cars have a cable setup for the windows and they do tend to break at times.
makes sure you are getting power to the motor before you start to dismantle everything in the door
Jun 19, 2010 | 2003 Chrysler PT Cruiser
Jeep Sport Cherokee Window
you need a window trac assembly
Jun 13, 2010 | 1998 Jeep Cherokee
Power windows and Locks don't work
Will the power lock work from the passenger side button?
If it does, its just your switch assembly.
Hth.
Apr 18, 2017 | Chevrolet C2500 Cars & Trucks
Windows wont let down only driver side
you can take outhte switch and reverse the connections on the dr door switch so dwn is up and up is dwn to see if its the motor or switch ...
May 07, 2009 | 2000 Buick Regal
Driver power window wont work???
sounds like your window lift motor may be bad but you can test it by
The window switch and master switch are actually wired in series. A problem with either switch affects motor operation.
A dead motor can be diagnosed with a 12-volt light or voltmeter by first ensuring that B+ is available to both switches. Moving the switches should switch the B+ from one side to the other. By connecting a testlight across the switch, the presence of voltage and the switch itself can be checked.
The motor is checked easily by jumping the terminals to B+ and ground. Reversing the connections should reverse the direction of the motor, raising and lowering the window.
Corroded switch contacts are a source of excessive resistance.
Nov 09, 2008 | 2000 Chevrolet Blazer
Power windows
Remove the front door trim panel.
2. Disconnect the 2P connector from the motor.
Connect the motor terminals directly to battery voltage (12V) and check that the motor operates smoothly.
Next, reverse the polarity and check that the motor operates smoothly in the reverse direction.
If the operation is abnormal, replace the motor.
Aug 08, 2008 | Hyundai Accent Cars & Trucks
Turbos, Nitrous, Superchargers for Ford Futura Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
