Maytag HYE3658AY Electric Dryer
Problem for Maytag HYE3658AY Electric Dryer
Noise when running
By nickstipper on Jan 22, 2009
the dryer makes a loud squeek empty or full, sounds like the belt is slipping
Same Problem
Feb 09, 2009
-   When I turn the dryer on it makes a very loud noise. While it is running, it sounds like there are sneakers in the dryer-even though there's only
clothes drying!-   jgtvegas
Solution #1
posted on Jan 23, 2009
Not Rated)
freetek
Rank: Guru
Rating: 85%, 1830 votes
If it was the belt, it seems it should slip more when loaded since the torque needed is greater then. A bad bearing might do just the opposite; holler when empty and quiet somewhat when loaded.
If the back panel can be removed without disabling the machine, it might be possible to locate the source of the noise better and it may not even be necessary to have the dryer running if (after unplugging it) the drum could be turned by hand while another listens at the rear.
Was this helpful?
Yes
No
Solution #2
posted on Jan 22, 2009
Not Rated)
danromarris
Rank: Guru
Rating: 90%, 82 votes
It is probably the rollers that the drum sits on. When these get old they loose their grease and start to seize up. They will start to make a terrible noise when this happens. They are cheap but kind of a pain to change out. They sit on the front of the drum and some models have them on the rear. In order to change them out you need to remove the drum. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad that I could help.
Was this helpful?
Yes
No
Popular Solutions for Maytag HYE3658AY Electric
Questions and Unsolved Problems for Maytag HYE3658AY Electric
Do you recommend Maytag HYE3658AY Electric Dryer?
Answer
Answer
my maytag dryer wont start and the drum light doesnt work anymore. what is the problem? dryer is... (More)
Answer
where are the thermostats located on this dryer?
Answer
Hi! I have a Maytag HYE3658AY and it shut off in the middle of a load of laundry with no warning. We... (More)
Answer
I replaced the element to find that it was not bad , so I replaced the thermostat on the element... (More)
Answer
My dryer is not working, when i tryied to turn it on. I got it zapped me. I looked for burnt wires... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
