Question about Sony Ericsson Z550i Cellular Phone
Not charging I connected the charger but not charging appearance in display
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Ericsson Master
  • 1,001 Answers
  • USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 16, 2016
    Master:
  • 520 Answers
Hello My Dear Friend::::::::::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jan 12, 2013
How touch pad that has been flashed over to android and at first it would not charge because I did not have the right charger now it will not charge at all and is taking me back to the flash cyanogen
Touchpads are really sensitive to the type of charger and cable that is required to charge them. I have had trouble charging mine in the past, but the best form of charger appears to be a touchstone.
It might me worthwhile getting a specific USB charger for the Touchpad that provides enough output. A normal phone charger does not have sufficient power.
Quote from another source:
If you have connected your HP Touchpad to the charger only to find that a charging symbol is perpetually displayed, you will probably need to reset the tablet.
This is done by holding the power and home buttons at the same time for around 15 seconds. During this time, the tablet should shut down, restart and then boot into the installed operating system - albeit with a very low charge.
Mar 21, 2015 | HP TouchPad
Does the camera display a light when it is charging? I have it connected to my computer but there doesn't appear to be any evidence of it charging.
As I understand these kind of cameras does not charge when connected to a computer. You need a separate charger.
The A460 uses 2x Size-AA Alkaline or NiMH Batteries.
Feb 26, 2015 | Canon PowerShot A460 Digital Camera
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My x8 not turn on and not charging !!!
Good morning:
First Option:
Second Option:
Jan 04, 2013 | Sony Ericsson XPERIA X8 Cell Phone
Phone is using more current than the charger is able to deliver
First Option:
Second Option:
Dec 02, 2012 | Cell Phones
My LG will not display that it is charging It is not responding
First Option:
Secend Option:
Sep 01, 2010 | LG enV VX9900 Cellular Phone
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Oct 16, 2008 | Apple iPhone Smartphone
Camera won't charge
If your camera appears to be in working order, your charger or the power outlet may have an issue.
With all connections intact,
1) Please try to connect the charger to a different power outlet and try again.
2) If the charger doesn't appear to show any indications of charging, try with a different charger.
3) If the charger works fine, there may be something wrong with the battery - or the camera. In such a case, please consult an authorised service center for a resolution.
Thanks!
Jul 19, 2008 | Sanyo Cameras
Sony Ericsson Z550i Cellular Phone Logo
46 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
