Question about Braun Cruzer 3 Electric Shaver
Oiling my razon
Where am I suppose to place the oil? I have the bottom end Braun razor, the one with no bells or whistles.
Thanks
    Problem Solver:
  • 7 Answers
Run a small amount of oil acrossed the blades. if they dry out, the blades will quit moving.
Posted on Feb 16, 2009
How to re-attach the metal spring on a vintage Braun Electric Razor with Trimmer Model #5564?
I struggled with this for a while too till I found a diagram. Place the wire spring and the flat detente spring (all the way to the bottom of the slot) in as shown in this diagram. When the trimmer plate goes all the way in, the spring will snap into its correct final position. Lee
Dec 17, 2017 | Braun Health & Beauty
I have a Braun 760 razor. The two electric contacts on the charging/cleaning base no longer make good contact with the razor. One of them seems to have some corrosion on it and prevents the razor from...
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
Sep 28, 2010 | Braun Series 7 9585 Hair Trimmer
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Jun 12, 2010 | Braun 360° Complete 8985 Electric Shaver
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Cruzer 3 Electric Shaver Logo
652 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
