Question about Furniture
Why does my car stool when full throtle is applied
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
Jul 24, 2012 | Furniture
I have a few swivel bar stools in my kitchen but two of them are squeaking, how can I fix them?
First turn the stool on its side and check all the bolts on the legs. If they are ok, rest the bar stool upside down so you can get a look at the underneath of the seat. Check the bolts there too. Once you are sure all bolts have been tightened return the stool to its upright position. Next you will need a can of high quality lubricant which you will need to apply to any squeaking area.
Are kitchen bar stools any different from commercial (pubs/bars) bar stools?
Essentially, there is no difference in the function of the stool; however the height varies slightly. Kitchen bar stools are 23-28 inches from floor to seat whereas commercial bar stools measure 29-32 inches.
Refill valve
This happens when the seal on the flood tube is leaking and there is an imperceptible leak into the bowl.
Jul 13, 2012 | Kohler Home
New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
Nov 05, 2011 | Poulan 25CC Gas BlowerVac
I have a Husqvarna 136 / 141 model chainsaw - it has been idle for several months. After starting and allowing to warm up for a minute or two and then attempting to use it - when applying full throtle the...
Has the chain stuck to the bar.? Chain oil has a tendancy to turn to a gluey state when say for some time. Is the chain brake fully releasing.?
Aug 29, 2011 | Husqvarna Garden
Engine will idle but when throtle is applid it dies
Check fuel pressure & TPS. (Throttle Position Sensor)
Jun 04, 2009 | 1999 Dodge Grand Caravan
Furniture Logo
75 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
