Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Refrigerator is hot but the freezer is cold
This is a brand new refrigerator only had it for 3 months and the bottom is completely hot not getting cold at all but the freezer is really cold even forming ice. What can be the problem be?
  • Sub-Zero Master
  • 17,130 Answers
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jan 12, 2013
Rotu
  • 175 Answers
SOURCE: refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Posted on Aug 16, 2007
Krazytech
  • 725 Answers
SOURCE: Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Posted on Oct 12, 2008
  • 8 Answers
SOURCE: refrigerator not getting cold
Chech blower fan POSSILE Burned UP clean coils see if fan works, or check compressor in supper HOOOT, possible burned.
Smell , does it smell like like burming tar or burned food.
Posted on Dec 11, 2008
SOURCE: bottom freezer on Subzero refrigerator not thoroughly freezing
the aspiring air in the freezer botton don't work... sorry for english, i am french...t k
Posted on Jun 21, 2009
heatman101
  • 43501 Answers
SOURCE: Sub zero 611 refrigerator error code 40, freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
Do not use ice maker and it makes noise
What is the complete model number of your unit?
Nov 25, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer cold, refrigerator sometimes cold sometimes hot
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | GE Profile Stainless Bottom-Freezer...
My fridge isnt cold freezer is our friend gave it to us she has no idea its our grage fridge fridigdare elite not brand new
heatman101
May 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Refrigerator is not getting cold.
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Mar 30, 2010 | LG LBN22515 Bottom Freezer Refrigerator
GE Refrigerator with freezer on bottom
check to see if you turn on control if on call service
Apr 03, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
101 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
