Question about HP e154554 - Cn0316-sn30-0v03 New Oem F700 Laptop Webcam Modul
HP e154554 pin description (Can i make it a USB)
HP T45 Connectivity Problem
You may check the link below for manufacturers that sell this product that you need.
Link
Aug 04, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Large data transfer laptops, cable, or USB adapters DELL Lat-C
to print using a usb port to the printer install a network card which can be obtained from any printer repair shop
Nov 23, 2008 | Dell 5100cn Laser Printer
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
HP e154554 - Cn0316-sn30-0v03 New Oem F700 Laptop Webcam Modul Logo
350 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
