Question about Husqvarna Designer I
Husqvarna Viking #1plus bobbin problem
Some threads got jammed in my machine and after I cut them and cleaned them out I had a problem with the bobbin tension. The bottom of my work looks better than the top. It seems like the bobbin thread is being pulled to the top. I have noticed the thread pulls out of the case very loosely so I tightened the screw on the bobbin case It made no difference. I checked it for threads or fuzz but found none. Any advice? I am having the same difficulty when embroidering. The bobbin thread is completely pulling through to the top of my design it looks awful. Sewing it works just fine. ThanksIn making embroidered napkins the first several were just perfect. On the 4th one the bobbin thread appeared to be pulled through to the front of the design. I've tried changing stablizer, needle, cleaning bobbin case, changing bobbins and still the problem exists. I know it isn't the design as it worked perfectly the first few times. Haven't tried invisible bobbin thread but that is the next step. Does anyone else have any other suggestions? They would be appreciated.
  • kjean1 Feb 04, 2009
    I have purchased pre-wound husquvarna bobbins, cleaned the bobbin case thoroughly, changed needles, tried using various types and weights of stabilizers to no avail. The first three times I used the pattern the embroidery was flawless, since then the bobbin thread has shown through. Is there some setting or other machine function that is causing this?
    President:
  • 2,559 Answers
You will need to override the (AUTOMATIC SELF ADJUSTING TENSION) in settings menu.
Posted on Feb 04, 2009
    President:
  • 1,990 Answers
Welcome To Fixya! I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line. Please Rate My Response! Thanks!
    Genius:
  • 1,199 Answers
This sounds like the bobbin thread tension adjuster is broken and will need fixed
Posted on Jan 22, 2009
    Genius:
  • 1,550 Answers
A burr in your presser foot’s needle hole may be cutting your thread.
Lint or dirt between your tension disks may be keeping your tension from working properly.
Clean out any you find.
  • 19,396 Answers
To start reset your machine settings, so to ensure it is not a setting problem. Check if you have the problem only with a specific settings and needle type/size.
Ensure that you are winding the bobbin slowly enough so to allow less stretch to the thread
If you have done all the rest, then try using invisible or monofilament thread.
Posted on Feb 03, 2009
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
Why is my bobbin thread jamming on viking juliet sewing machine
Be sure to clean out any stray fibers or threads in the bobbin area. Make sure the bobbin is smooth and doesn't have nicks or scratches.
Aug 02, 2014 | Husqvarna Sewing Machines
Why is bobbin tread jamming on my husqvarna viking juliett sewing machine
Most of the time, you should rethread the machine, take the bobbin out and put it in again and change the needle. Generally if it is jamming under the fabric, it is because something is wrong with the top ie rethread the machine.
Thread bunching up around bobbin
If you do not have a user guide, you might want to find one. Try ebay or have an authorized Husqvarna Viking dealer order you one. In fact I would find your nearest authorized Husqvarnia Viking dealer and visit them with you machine. They should be able to help you and usually are very helpful even if you didn't buy the machine from them. If they determine it is correctly threaded and the bobbin is ok, have it serviced by an authorized Husqvarna Viking dealer or have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for service. The machine should give you years of good performance.
Use only genuine Husqvarna Viking bobbins.
To find an authorized dealer near you, check the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Dec 15, 2008 | Husqvarna Designer I
Machine not working
I had this happen the first day I got my machine. The bobbin case has probably came loose from the holder. There is a step by step cleaning instruction in the manual and it tells you how to reset the bobbin case in the holder in the manual.
Nov 15, 2008 | Husqvarna Viking 1
Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jul 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
70 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
