I can't get any channels on my tv and tried every thing I know like tuing it
  • 1,238 Answers
Disconnect and re connect all wires and cable from TV to cable box
Posted on Jan 12, 2013
Dish tv 2 works but only very fuzzy on channel 56 dvr
ssmike1,
It sounds like you may have just switched off the channel to view satellite.
The channel for satellite is based on the connection you're using. If you're using a coax connection, it should be on channel 3/4 or 62. If you're using video cables like RCA/HDMI then you'll need to switch the input. On the upper left of the remote should be a TV/Input button. Make sure you're in TV mode and press that to see if picture returns.
If the problem continues let me know and I would be happy to try some additional steps!
Tommy Faust
DISH Social Media Representative
Feb 15, 2012 | DISH Network IR Remote Control
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Jan 23, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Hi. I have the sharp tu-tv 322h which I bought from someone else. Its been sat in its box for a year unused and so when i switched it on and set it up i could only get one or two channels. The others were...
You should be able to get all the standard freeview channels without bothering with TopUP TV.
Follow the Instructions on Page 24 of the Manual at the link below.
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/DTR/TUTV322H/TUTV322H279.pdf
If this doesn't tune all the Stanadard Freeview Channels then you're not getting a strong enough signal for this unit so it won't be able to upgrade the TopUP TV side of it.
Jul 14, 2011 | Sharp TUTV322H
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
I don't know how to set the tv to receive all of the channels
Enter the "menu" and select auto program. This will allow the set to search for all available channels. There is also a possibility that when you hooked it up the little wire center conductor in the cable might have been bent over when you hooked it up. Check that first.
Apr 16, 2010 | Sharp 19R-M100 19" TV
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
