Question about Whirlpool 24 in. ADG6552 Built-in Dishwasher
How do i fit a new drain hose - Whirlpool 24 in. ADG6552 Built-in Dishwasher
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
I need to drain my Reliance electric water heater. I will use my garden hose to drain the water to the outside. Problem: none of my 3 garden hoses will screw onto the drain faucet fitting on the water...
The drian hose fittings on many water heaters are a cheap plastic that are mass produced who knows where. For this reason and others, the thread paters are not always perfect. All hose threads should be the same. Installing a new (brass) drain valve will solve the problem. You can call Reliance and ask for a free replacement if your heater is still under warranty.
Sep 14, 2010 | RELIANCE ELECTRIC WATER HEATER
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
Jun 11, 2010 | GE WBSR3140DW Top Load Washer
Change drain hose
Should be quite simple to do Eddie. Its secured by a clip onto the pump outlet undo this fit new hose resecure .Fully Watertest before use ..
Jun 04, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Water remains in bottom, water pump out?
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain solenoid.
Apr 25, 2010 | GE Dishwashers
Machine does not empty new pump fitted
Check the drain outlet hose for a possible blockage, also check the filter located inside the large black hose fitted to bottom of drum.
Please rate my solution.
Thanks.
Nov 05, 2009 | Hotpoint WMA30 Front Load Washer
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
HOW DO YOU TAKE OFF A POWER STEERING LINE? I HAVE A 96 FORD E150 5.8
When power steering hose replacement is required, follow these steps:
  1. With the engine stopped, remove the return hose at the power steering gear, and allow the fluid to drain from this hose into a drain pan. On some cars, the vehicle must be lifted on a hoist to replace the power steering hoses.
  2. Loosen and remove all hose fittings from the pump and steering gear.
  3. Remove all hose-to-chassis clips.
  4. Remove the hoses from the chassis, and cap the pump and steering fittings.
  5. If O-rings are used on the hose ends, install new O-rings. TRW steering gear cylinder lines have gaskets that are serviced as a unit. The old gasket must be pried out of the fittings in the housing before the new lines and gaskets are installed. Lubricate O-rings with power steering fluid.
  6. Reverse steps 1 through 4 to install the power steering hoses. Tighten all fittings to the manufacturer's specified torque. Be sure all hose-to-chassis clips are in place. Do not position hoses where they rub on other components.
  7. Fill the pump reservoir to the full mark with the manufacturer's recommended fluid. Bleed air from the power steering system. Check the fluid level in the reservoir and add fluid as required.
Jul 07, 2009 | 1996 Ford Econoline
Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Whirlpool 24 in. ADG6552 Built-in Dishwasher Logo
18 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
