Home | Toshiba | CF36G40 36" TV | Toshiba CF36G50 Noi...
Toshiba CF36G40 36" TV
Problem for Toshiba CF36G40 36" TV
Toshiba CF36G50 Noisy when you turn it on
By cwk3980 on Jul 05, 2007
When we turn on the TV set, toshiba CF36G50, it is really noisy. Sounds like static. Sound like a looks connection somewhere but after about 5 minutes, or after it "warms up" it goes away, until you turn it off and then turn it on again. Any help would be greatly appreciated.
P.S. The set is still using rabbit ears, yes, I said rabbit ears. Very poor cable and satellite reception in the area.
Thanks for all your help!
Regards.
Comments:
Oct 26, 2008
- Where can I find a diagram of the inside of the set? I am a real novice when it comes to this. Is this something I can really do or should it be taken in? Thanks....
Best Solution
posted on Aug 05, 2007
Very Helpful)
snakehead
Rank: Wiz  Toshiba Expert
Rating: 81%, 1014 votes
that sound is comming from the tube anode it is leaking you have to discharge the high voltage from the anode cap,then take off the cap clean the area with alcohol and put some red or clear silicone on the cap and anode connection replace back the cap on the tube leave to dry for about half hour,this will remedy your problem,no more static.good luck.
Was this helpful?
Yes
No
Popular Solutions for Toshiba CF36G40 36" TV
Questions and Unsolved Problems for Toshiba CF36G40 36" TV
Do you recommend Toshiba CF36G40 36" TV?
Answer
Answer
trying to remove a horizontal line from the left of the tv.plz help.
Answer
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to... (More)
Answer
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable... (More)
Answer
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden... (More)
Answer
I have a Toshiba TV (model# 23319197). The audio output ic part is out and Toshiba has discontinued... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba CF36G40 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
