Question about Saws
Elu v/cs/630/q mitre saw blade spins
The clutch on the saw does not seem to be engaging either blade spins but not at the correct speed and won't cut
stug_57u
  • 99 Answers
SOURCE: dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Posted on Nov 01, 2008
rowdy45176
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
SOURCE: ryobi compound mitre saw sliding 10
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Posted on May 08, 2009
SOURCE: how do I change the blade on mastercraft compound mitre saw
I have the same question.
Posted on Apr 17, 2011
1991 Mercedes Benz AC Cycling Switch /Compressor Clutch Won't Engage Completly Spins 1/6 of a complete spin repetedly then stops
You need to have the refrigerant charge level checked, it sounds like it is low. You Need a set of AC pressure gauges to do this testing. If the system has a low charge the pressures will be very low in the low side testing port.
Jun 26, 2012 | Cars & Trucks
Blade brake dosen't work right away when switch is released. Takes a couple seconds of slow spin then the brake seems to stop the brake. Suggestions?
All blade brakes take a moment to stop the blade. If it were to engage as soon as the switch were released the inertia of the blade would do damage to the saw. Look at videos of your saw on youtube to ensure it is operating the same as others.
Jun 12, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
Huskee model 287707 blades wont spin belt not broke or spinning?
check for power and ground at the connector that feeds the clutch this will tell you if its a switch or the clutch itself
May 23, 2012 | Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
How do you replace the blade on as Protech 8 1/4 inch compound mitre saw? i can't get the blade to stop spinning and i can only get to one side of the attachment bolt.
there should be a spindle lock on the opposite side of the blade bolt,, make sure that when you replace the blade that you install the flanges correctly and if there a spacer that it is in place.
Dec 22, 2009 | Bosch 12" Compound Miter Saw 3912
Saws Logo
60 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
