Question about Liberty Pumps LCU-20S Condensate Pump 115V Automatic w/ Safety Switch,
Condesate pump Liberty Pumps LCU-20S became noisy, went in to crawler to check it, 2 lines were dry and dirty(coming from Furnace and Dehumidifier I believe), the other connected to what I assume was the pump and not the extremely dirty reservoir tank had water in it. When I moved it to inspect it shut itself off. I,m a first time homeowner and not sure if I should be extremely concerned about this, any suggestions?
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    Why is a bhd501-d dehumidifier very noisy?. can you give me any ideas on fixing this?
    Try pulling the grill off and see if the fan blade is rubbing on something. Check if anything else is loose while you have the cover off..
    Jun 05, 2014 | Comfort-Aire BHD-301 Dehumidifier
    I need to replace the bearings to a water pump motor, since it became very noisy after it worked overheated for some time. This is an Emerson Model C55CXHMP-4142. Other nameplate info : 3450 RPM INS
    Bearings are pressed onto the motors shaft. You will have to use a gear puller to remove them. And then press the new ones back on. To access that, you'll have to remove the front and rear end bells.
    then use exact replacements!
    then reassemble.
    Electric motor shops do this all the time. Take it there, if you don't want to try doing this yourself. You probably can search YouTube, and find a good tutorial.
    https://m.youtube.com/watch?v=-dswCzYlmNE
    May 01, 2014 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
    Can't get my creepy crawler to work in my pool, i have a purex triton filter system, i can't get any suction on from the crawler
    It sounds like your automatic pool cleaner might have a leak that is causing the pump to lose its prime. Check the hose to make sure that there are no leaks or cracks. Check the vacuum connection. It should be submerged so no air enters the system. Look and check the pump basket lid for looseness, cracks, and worn or missing O-rings.
    Feb 26, 2011 | Universal Kreepy Krauly In-Ground Pool...
    Dishes and the dishwasher look dirty after they run, like it redistributed dirty water. The door is very dirty/filmy except right under the soap dispenser, like someone squirted dirty water on it but wiped...
    Did you say both of your dishwashers were doing the same thing? Are they the same brand and did you buy them together. It could be a seal in the pumps motor leaking and oil is getting in the water, that is if your pump pumps your water in and pumps it out. Some models the pump pumps the water in and out, other havw a water inlet valve that electrical opens to let water in and the pump just after the cycles pumps the water out.
    Dec 30, 2009 | Dishwashers
    2004 power steering pump whinning. Changed pump and noise is still present
    Ford is notorious for having very noisy pumps. Yes even the replacement pumps. Having some noise in a ford is unfortunately normal.. but I would assume you may have dirty fluid still in the line.. Get the system flushed then see if it goes away. Good luck
    P.S dirty or old power steering fluid can cause poor pressure in the power steering system hense the reason to flush the system
    Dec 01, 2009 | 2004 Ford Taurus
    Liberty condensate pump LCU-20S never shuts down and is loud
    Had the same problem today. What I did to fix this was to disconnect the unit and shake it so that the float became free. Once this was done, I reconnected the power and drain tube and PVC lines and primed the pump with about 32 oz of water to activate the pump. All works fine now.
    Mar 16, 2009 | Liberty Condensate Pump 20' Safety Switch...
    2002 V6 Jeep Liberty-Oil Pump Replacement
    Yes you have to check your pressure with a mechanical gauge first. If the pressure reading is good replace the oil pressure sending unit. They are known to go bad, and oil pumps going bad is rare.
    Oct 29, 2008 | 2002 Jeep Liberty
    Furnace ices up,lines ice up,water condensation leaking in to duct work
    1.check filter if really dirty change
    2. check Refrigerant if low get charged by a tech
    3. check the evaporator coil if dirty clean
    Oct 16, 2008 | Heating & Cooling
    Liberty Pumps LCU-20S Condensate Pump 115V Automatic w/ Safety Switch, Logo
    23 people viewed this question
    Top Liberty Pumps Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Liberty Pumps Plumbing Expert? Answer questions, earn points and help others
