Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Bosch 6802UC dishwasher is leaking water from bottom of door
I have a bosch dishwasher. I turned on the long cycle and noticed that water was dripping after 1 hour. While the unit was operating, I reached under the door and the padding was dripping wet.
I live in Malibu and would like it fixed unless it is cheaper to buy a new model.
  • alanjohnson2 Feb 16, 2009
    dishwasher leaks water at the door and now has little water in it that will not pump out or add more timmer is counting down also a butning smell
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SHU4302 DW has a leak in the bottom left. I cleaned the gasket etc. but no luck. Slow leak drip by drip in the wash cycle. This model does not seem to have the steam vent that other Bosch models...
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Dec 18, 2009 | Bosch Dishwashers
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I need to change the door gasket on my Whirlpool dishwasher
Leaking Dishwasher
heatman101
uioypoiy[
Feb 18, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Bosch SHU3036UC not filling with water
u need more info first what happens when u shut the door and start a cycle
Nov 05, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
554 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
