Question about Linksys WRT120N Router
Bonjour compatible linksys WRT120n
Is linksys WRT120N Router bonjour compatible
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
govinda123
  • 2263 Answers
SOURCE: How to configure our router, linksys wrt120N,
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Feb 05, 2010
govinda123
  • 2263 Answers
SOURCE: unable to connect to the internet with my linksys
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Posted on Feb 16, 2010
govinda123
  • 2263 Answers
SOURCE: error 321 linksys WRT120N
Are you trying to run the CD that comes with the router ?
You get this error when your computer is not able to connect to the router.
Actually you can say that it is a bug in the CD.
Even if your computer is connected to the router, it will say that it is not connected.
You can set up the router manually without the CD.
make sure that your computer is connected to one of the Ethernet port on the router.
Reset the router for 30 seconds. wait for 1 minute.
unplug the power to the router and plug it back in.
Wait for a minute and try to set up the router manually.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on May 20, 2010
  • 177 Answers
SOURCE: WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
Posted on May 22, 2010
How do I find network key for wrt120n router
You will need to check the setting of your wireless router.
Do you have any computer connected to the network?
Using one computer connected to the network, you can open the router page and check the wireless router settings.
Check this link for Linksys WRT120N router setup and troubleshooting
Oct 15, 2014 | Linksys WRT120N Router
Factory restore
According to Linksys support, you should not reset your WRT120n wireless router unless you are having difficulties with the unit. The WRT120n user guide also recommends applying other troubleshooting options before attempting to reset the device. Resetting the WRT120n restores the router back to factory defaults. After resetting the Linksys 120n, you''ll have to reconfigure the router back to your preferred settings.
Locate the Reset button on the back panel of the WRT120n. The button is labeled "Reset" and situated between the power port and the "1" Ethernet port. Press and hold down the "Reset" button for five seconds. The device resets. Open a Web browser on your computer. Type "192.168.1.1" into the browser's address field, then press "Enter" on your keyboard. A login prompt opens. Enter "admin" as the password. Leave the User Name field blank, then click "OK" to log in to your router and access your network settings.
Apr 02, 2013 | Linksys WRT120N Router
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
You can do it manually without CD.
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
Oct 13, 2011 | Linksys WRT120N Router
I just bought linksys wireless router wrt120n but my labtop doesnt have cd driver hoe can i do the set up wizard with a cd?
Thank you for using FixYa
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
you can download the installation application following the given link
Jul 20, 2011 | Linksys WRT120N Router
I want to connect d'link 2640t to linksys wrt120n, hi i have a DLink 2640T modem+router with IP 192.168.2.1, i want to extend my home network so i bought a WRT120N router with IP 192.168.1.1, i am...
This is too involved to just post your router settings. I would recommend reading up on how to "cascade" your router or to make your Modem/Router act as a bridge.
The dlink will need to have its DNS disabled and have the Linksys do the DNS. Then the LInksys will be using the Dlink as its host. you may be better off seeing if you can make the dlink run in Gateway mode instead of router mode.
Then see how to implement the cascading router with your particular situation and WAN IP.
Jan 02, 2018 | Linksys WRT120N Wireless Router
Is the wireless120 Router compatible with dell
Yes it is very much compatible with your XPS M140 that transmits 802.11 b & g wireless connection. In which the Linksys WRT120N Router can accept a/b/g and N wireless connections.
I highly recommend this router if you want to use one.
Jan 04, 2010 | Linksys WRT120N Router
Linksys WRT120N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
