Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony KP-57WS500 I would like to know if the convergence can be adjusted manually through the service mode and if it can how? thanks Bear
    Novelist:
  • 159 Answers
Bear:
the process has to be done in the service mode as you are asking and is not a big deal to show you the way to be in those pages. The problem is not to be in the door but to drive inside there by yourself in this computer program language and you are not familiar the probability to disturb the program is high and create problems worst than a solution as lost audio, channels or who knows. Best thing to do is to find a friend who knows about it and teach you to survive in that rare atmosphere and then you can do any tv adjustment. good look.
Posted on Apr 25, 2009
Replaced convergance chips adjusted red but blue will not adjust in any direction pico fuse is good Sony KP-57WS500
You can try to adjust in service mode but it sounds like you did not do this repair correctly. I would suggest getting instructions from sites such as www.TvRepairKits.com
Feb 12, 2012 | Sony KP-57WS500 57" Rear Projection...
Can I manually adjust the convergence on a Sony KP 57WS500
that model has an auto focus so if thats not correcting the issue then the ICs will need replacment. The sony type 1 convergence repair kit from www.tvrepairworld.com should solve the issue.
Feb 22, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv turns on but has a shadow around evrything
Do you have any speakers or magnets next to the tv? If so, that is not good.
It may be a convergance issue. Check to see if you have any adjustments on the back of your tv to adjust picture. If not, if may be a faulty capacitor that needs to be replaced
Jul 02, 2009 | Sony KP-57WS500 57" Rear Projection...
How do i get to service screen on sony kp-57ws500
Hi, you need to purchase the service manual, without it you cannot access whatever you want to adjust, serv. menu has many different menus & sub menus, you didn`t say what you were specifically looking for but you will need the manual, gl, video-tek
Jun 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Converge problem on a kp-65ws500 sony rear proyection tv
You can download a copy of the service manual that explains how to enter service mode and perform convergence of the red/blue/green guns, but unless you are comfortable doing something like this, you may be better off calling a good shop familiar with rear projection sets and getting a quote to have a convergence service performed.
Dec 16, 2007 | Sony KP-57WS500 57" Rear Projection...
Kp51ws500
Best to get a tech to verify problem--you may need a convergence circuit repair==change the STK IC's and then check convergence.Please describe symptom as you see it,if you want more assistance.
Sep 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
