Question about HP PSC 1210 All-In-One InkJet Printer
Will not copy info. off the internet
The ink is good, the copy part is good, the test from the main system came out good, and it told me everything was hooked up right. I have had it for about 5 years. gunmag56@yahoo.com
  • 20 Answers
Are you able to print from other applications like a microsoft word page, or a print test page. If thats the case than check your Internet options. If you are using an Internet EXplorer web browser than try to set all  internet settings on the option menu to default. This should resolve the issue. Else try to  use a HP 990C pritner. Add the 990C printer and try to print an internet page, it should work.
Posted on Jan 22, 2009
I have an older HP color copier 190-it has new ink but keeps saying align ink cartridges-how can I get it past this
with the older types some of them when replaced the ink you have to do the alignment test for the system to reset for printing
Aug 29, 2016 | HP Office Equipment & Supplies
Crank but will not start, is not getting spark in plugs
Have to learn how to test the ignition system components
Should find that on the internet in many,many places
Just ask the question & provide your vehicle & motor size
You Tube Video is very good for info on everything
Jul 29, 2014 | 2000 Mitsubishi Galant
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
Ink idling problem in gestetner dx 2330 copy printer
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.
Strip and clean the blocked gauze filter in the Ink Supply System.
Jun 24, 2012 | Gestetner Office Equipment & Supplies
My printer's ink absorber full.
Hello
Although the software resetter for the Canon Pixma MPC190 printers has available on the internet but before using the software you must reset the printer manually. But manual reset can not reset the counter printer permanent, to reset counter permanent require software resetter such MPTool or Serive tool software. Reset for Canon Pixma MPC190 Printers Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy Choose TEST MODE. Select 8 PRINTER TEST TEST MODE. Choose 3, EEPROM CLEAR Select 0, INK COUNT Press the Set button. Click Stop / Reset button (return to item 3), and again press the ON / OFF Good Luck
Feb 26, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Canon MP180
That error code is described below:
Error Code Error indication Error condition.
5B00 Waste ink full H/W fail Replace printer.
And i would like you to refer to www.feedroller.com/Store/Service%20Manual/S100sm.pdf
Thos document has all the error codes and what needs to be done for that.
Hope my info is useful,
Thanx for using fixya.
Sep 26, 2008 | Canon PIXMA MP180 All-In-One InkJet...
My red ink will not come out
the big prob with generic ink is that some additives are missing which are needed to keep the ph working.
try this:
press menu then start bk copy then 4 times arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then OK or start bk copy. machine will supply fresh ink to tubes and ph. when finished press 7 then 6 then 3 then ok or start bk copy. machine will run a power purge. leave maintenance afterwards by pressing 9 then 9. Do run a test print by pressing ink etc.
If there is still no mag. the valve or part of the ph is rotten and cant be fixed anymore!
Dec 12, 2007 | Brother Multi-Function Center MFC-240C...
HP PSC 1210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
