Question about Westinghouse WGQ332HS 5.7 cu. ft. Gas Dryer in White
Westinghouse oven no gas but supply and power is good
My oven will not light. Gas supply to other appliances is good and electric power is on. Fan light clock and ignition is working but no gas or smell when I push the knob for grill or oven for a long time
    Sergeant:
  • 211 Answers
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Posted on Jan 12, 2013
All electrics have gone in my gas oven, no fan, light or ignition is there a fuse or something that can be fixed by us
check if the breaker tripped, sub panel usually indoor, establish power at the power outlet where your stove/oven plugs into. If you have power at the outlet, then look for a inline fuse in the wiring.Usually located in or by the circuit board for your appliance.
Apr 03, 2016 | Belling FSG60DOP White 600 mm Gas Cooker...
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Thermador over two left burners will not provide gas when knobs are turned. Also the oven will not light and the igniters on all burners will not spark. The electric is good to the appliance oven fan
You have multiple problems! First the single igniter that fires in all of the burners is either broken or disconnected electrically. Second, your gas lines or nozels at some of the burners are clogged. Check for cloggs by using a match as you light ONE BURNER AT A TIME...If they all light you only have the electronic igniter to troubleshoot...Have a repairman check it out for you if you don't feel confident with gas!
Dec 21, 2012 | Kitchen Ranges
Stoves 900DFa oven cuts out
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Nov 18, 2009 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Gas burner doesn't work
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Westinghouse WGQ332HS 5.7 cu. ft. Gas Dryer in White Logo
308 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
