Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Connection problem l cant connect several 54 mbps wireless adaptor to the belkin F5D8230-4 pre n mimi router, any help???????
    President:
  • 2,961 Answers
It sounds as if either the router is not set at enable DHCP which gives your pc's wireless adapters an automatic assigned ip address, so check in the routers settings via your web browser normally by typing 192.168.2.1 and check that DHCP is enabled and look in the menus and see if the transfer speed is set correctly at 54 mbps, the same as your wireless adapters. Also go to your wireless network adapters in network connections in control panel, right click on your wireless connection icon and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok it and close window. The problem with 'pre n' routers is that this setup was released before the alloted 'N' type transfer speeds and required firmware, hence named 'pre n' and can be quite troublesome at times. If you go through the above proceedure they should all connect, but you must also check in my computer, right click then click properties and look at the computer name tab and check that all the pc's are set at the same workgroup name, normally 'workgroup' or 'mshome', otherwise each pc will not be able to see each other.
Posted on Jul 05, 2007
SOURCE:
Bt home hub 4
couldn't hurt to try a new one, but be warned, different manufacturers cards can get different speeds depending on the router you are connecting to.
Oct 03, 2017 | Belkin Computers & Internet
How to use router without using wifi in belkin n150
This model Belkin wireless router has 4 LAN ports so you can connect a LAN cable from this wireless router to your computer.
I suggest you disable the wireless in the router so no one can access your network and Internet. If you cannot disable the wireless then you can setup WPA2 encryption to secure your wireless network or just remove the aerial off the wireless router.
Mar 05, 2013 | NetGear WGR614 54 Mbps Wireless Router -...
What is the max download speed for a belkin g wireles route. mine seems to be limited to 2 MB
It depends on the router that you have.
If you are using a wireless G router, then the wireless speed will be 54 mbps. and if you are using N series router then the wireless speed will be more than 54 mbps.
Click here for more information about the routers
Oct 06, 2009 | Belkin Computers & Internet
Belkin Pre-N Wifi - Speed problem
When using a laptop that has a N-wireless card the computer will to connect to a G-wireless router the laptop will be able to connect but because the router is a G-wireless the speeds will not be as fast. speeds around 10 to 20 Mbps is about normal. I don't know why your computer is saying that you are getting speeds around 108 Mbps. Residential computers don't reach speeds that fast but some business computers running off of an T-3 internet will have speeds up to that high so that they can keep up with large amount of data being transferred over there networks. As for the USB, i have seen an USB adapter that was g-wireless at at Wal-mart for about $20-30.
Jan 05, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Problem with Pre n Router
54mbps is what the Belkin routers wireless signal transmits at! This cannot be altered and is working correctly regardless of other wireless card speeds.
Jul 10, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Problems with my router
netgear wireless usb adaptor wpn111 i get problem to connect internet for software
i am a weak user please help me my e-mail add: [email protected]
May 18, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Belkin n wireless usb speed problem
For your connection to reach 300 MBps, not only must your Belkin WiFi USB adapter be an N, so must your Access Point/Router also be N capable.  Additionally, your Internet/DSL connection would also be a limiting factor on your Internet Connection speed.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | Belkin Pre-N 802.11g/b Wireless Adapter
Router down when copy files
Check in your routers settings via your browser that the file transfer speed is no higher than 54 mbps, as it may be set at 108 mbps or 125 mbps as a 'g' type router should be, but your wireless network adapters can only work at 54 mbps and are crashing the transfers.
Feb 28, 2007 | Belkin (F5D5231-4) Router
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
What is the difference between 802.11g and 54g?
54g implements the latest draft of the IEEE 802.11g specification. The two primary distinctions between 54g and 802.11g are: 1) 54g is designed to enable 54 Mbps connectivity. The 802.11g draft specification makes 54 Mbps connectivity optional, and simply requires up to 24 Mbps connectivity to comply with the specification. 2) 54g products are based on the same wireless LAN chipset, which means they are interoperable. Because the standard is not final, it is not yet possible to test for 802.11g interoperability.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
119 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
