Question about Cameras
Iso setting on nikon d600 - Cameras
Nikon d600 origin
Believe it's China but don't quote me. Here is an excellent article on the D600:
http://kenrockwell.com/nikon/d600-d800-d4-are-the-same-camera.htm
Mar 31, 2014 | Nikon D600 SLR Body Only"
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
Nikon D80 won't allow use of auto ISO
Hi kathlag96, page 43 of the manual state that Auto ISO works in the Vari-Program modes. Page 88 item 7: explains Auto ISO does not work in the P, S, A, M modes
Jun 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
I bought the Nikon Coolpix about two years ago. Suddenly all the pictures taken are overexposed. What do I do?
Two things to check...ISO (should be auto ISO or a setting between 100-400) and Exposure Compensation (should be set to "0")
Feb 25, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
NIKON D70
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600? http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b11&num=12 Select ISO setting this way: http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b05&num=10 Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
Apr 02, 2007 | Nikon D70s Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
