Question about Konica Minolta Bizhub c203 Copier
My konita minolta bizhub c203 always jam paper at the by pass tray
When putting a thickness paper eg. drawing block 200gm at the by pass try for printing and always jam in the middle of the printing work.
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
  • 1294 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Bizhubman
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
My Bizhub C203 indicates that there is a paper jam at the exit. but i had checked and there is no jam. I also had replaced the fuser unit thinking it will fix the problem but the problem is still the same...
I have had in the past on these models that when paper is being fed to the exit section the exit rollers are not spinning so paper doesnt get pushed through to the output tray. If this is the case then you will need to replace the exit roller drive motor and possible the PRCB too as sometimes when the motor becomes faulty it knocks out the PRCB ICP chip on the board.
Feb 13, 2015 | Konica Minolta Bizhub c203 Copier
Paper jam
when coping or printing? make sure paper is in the tray the way you set it up in the tray settings on the control panel and the driver. paper size, orientation, and media type all make a difference. clean the roller and make sure the lift plate moves freely.
Jan 12, 2013 | Konica Minolta Bizhub c203 Copier
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
My Konica-Minolta-Bizhub-C350-Color-Copier-Printer paper keeps jamming, why?
well could be several reason incorrect paper size incorrect paper weight are you running Thick 1 or Thick 2 to paper. Do you know how to read paper weight? on out side of the paper package is words 20lb or 36lb mite also see the something like 75 g/m2 that is the weight of paper in the metric world (Every one else except the GOOD OLD USA.:):):) we use the lb. system . select paper on the control panel and make sure the paper weight matches most paper copy are putting both lb. and metric but if it is only metric then use the control panel to figure it as you select the thick 1 or 2 you will see the g/m2 on the control panel, if you using paper off the shelve and don't know then call the company where you get the paper from and ask them. Are using the bypass tray make sure that you follow the icon on the screen when it says load paper in the by pass tray does the little icon show portrait or landscape. if you using legal size paper did you pull out the extention tray to allow additional sensor to come into play for the longer paper. Does you print properties on the computer screen match what is in the draws? IF the paper come wrapped an only has lb. # then you will not find it on the control panel you need to get your operation manual out in that manual will be a chart that show what lb. # equals what thick 1 or thick 2.
Jan 05, 2012 | Minolta C350 Printer
How do I print index cards through my bizhub C203?
use bypass tray, you must use thick 3 or thick 4 and the size needs to be close to the size of index, the tray settings need to be set for thickness and size and color then the same has to be set in the driver in computer also, when you go to print hit properties and change the tray to bypass and thick 3 or thick 4 and then the same size you selected in the copier and it should work. if by chance it asks you load paper in bypass after you hit print then it didnt get setup correct. check to see if you got the driver saying the same as the copier tray. ask if you need help
Jul 28, 2011 | Konica Minolta Bizhub c203 Copier
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub c203 Copier Logo
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
