Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Yellow tints on screen and color is faded.......
What should I do to fix it?
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 16, 2009
    Your TV most likely has one or more possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Nov 27, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
BLUE FADED COLOR ON BOTTOM RT. CORNER
call sony customer service.They will accomadate a warranty fix for that particular problem at no charge.Tell them you say a bulletin on their website for that particular problem your having..
Nov 20, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
