Question about Dishwashers
Water light stays on constructa dishwasher
Tap water light stays on
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
How to use the dish washing machine 'Constructa'
open the door and put all the way to ur left inside the dishwasher and close the door start your washer
Feb 21, 2013 | Washing Machines
Runs for a few minutes then a light flashes le and it stays on but isnt running
Hi there Pereiraal the code IE relates to the water suply system, please check that the water tap is turned on, if it is the inlet valve may be at fault but first I would make sure the tap is on and you have water coming through to the machine. please let me know if this helps.
Jul 23, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Do not have the constructa dishwasher manual
service manual for dish washer construta
Apr 25, 2010 | Dishwashers
Red tap symbol lights up but no water comes in to dishwasher
I hate to point out obvious things, but did you crank your line tap all the way out clockwise? And if you are using a line tap, are you sure the piercing needle conpletely punched through the hose?
Try removing the water line from your dishwasher and opening the valve to verify water flow.
Mar 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Start light flashes 6 times
6 'start' led blinks indicates
WATER TAP CLOSED
Water walve is switched on but flow meter sends no impulses or sends less tan 10
impulses in 10 seconds and the water indicator is off (empty)
posible reasons:
water tap closed
water inlet hose closed
water inlet valve defective
flow meter defective
remember to unplug it from power if any repair is done
Best regards and good luck
Oct 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
